Catalyst control centre settings
for the anti-alaising should i tick the box that says(use application settings)
for the anisotropic filtering,should i do the same?? and what about disable catalyst A.I. option,what does that do??
also the...MITMAP DETAIL LEVEL...ENABLE ADAPTIVE ANTI-ALAISING...OPEN GL SETTINGS(TRIPPLE BUFFERING)...and also..WAIT FOR VERTICAL REFRESH(performance or quality)
NZXT apollo case
Gigabyte GA-EP45-UD3L, Intel P45/LGA775/ATX
4GB KIT(2x XMS2 2GB) Corsair 'XMS2' [TWIN2X4096-6400C5], DDR2/PC6400/800MHz
550W Greatwall -psu
500GB Seagate ‘Barracuda’ [ST3500418AS], 7200.12/SATA/16MB CACHE
Intel® Core™2 Duo E7600, 3.06GHz/FSB1066MHz/3MB Cache/LGA775
XFX HD 4770 512MB 128Bit,
Ask the community
