Motherboard Help!!!!
Hello, i have recently purchased a computer case (a midi) and need to buy a new motherboard, however i have seen this one (Gigabyte GA-G41MT-S2P G41 Socket 775 DDR3 Onboard VGA 7.1 Channel Audio mATX Motherboard) but am looking for any better ones,i cant afford to pay a huge amount, does anyone have any ideas?
4 answers Last reply
More about motherboard help
  1. I understand its probably a silly question,but any help would be appreciated
  2. what processor will you be using? 775 is an older socket is why I'm asking
  3. the honest answer is I don't know yet, I am trying to build my pc from scratch, and i have bought case which has dimensions of 430mm (l) x 175mm (W) x 360mm (H) and unfortunately the motherboard from my old computer is too big for this, so i just want some advice?
  4. What is the name and model of the case? How much money is a good price range? Are you wanting a CPU/MoBo Combo?
    What is better for your case, a Mini-ITX or a Micro-ATX?
    Mini-ITX is slightly smaller than micro-ATX and Mini-ITX boards can often be used in cases designed for ATX, micro-ATX and other ATX variants if desired...
Asus Motherboards Product
