Sabertooth 990FX HELP!! sound card
i have a sound blaster x-fi extreme fidelity gramers sound card
on the software that it gave me there is s speaker test the sound works :)
windows media player or games no sound ?? :(
1 answer Last reply
More about sabertooth 990fx help sound card
  1. Disable the integrated sound processor in Device Manager. That should do it.
    FYI, sound cards are basically pointless unless you have some kind of fantastic audio setup, and even then they push uselessness. There's no longer an argument to be made for taking work off the CPU, as the work that goes into sound processing is practically negligible.
Configuration Sabertooth Sound Blaster Sound Cards Windows 7
