Solved
I Need Help Picking a Power Supply!
  • Power Supplies
  • Management
  • Components
  • Product
Last response: in Components
August 17, 2011 4:37:52 PM
Here is my current arsenal of parts for my first homemade pc:
http://secure.newegg.com/WishList/PublicWishDetail.aspx...
I'm really excited but I can't put my hands on a power supply that pleases me. I need it to be at least 500w for my GPU, but would like more. I want it to be modular or partly modular because my case doesn't have great cable management, and last but not least, I want it to be somewhere in the $70 or under category because I am on a budget... Thanks! All help and suggestions are welcome!
More about : picking power supply
a b ) Power supply
August 17, 2011 4:41:10 PM
stretch your budget as far as possible--the power supply is the most important component in your pc
corsair or similar quality
m
l
a c 144 ) Power supply
August 17, 2011 5:50:41 PM
It's an OK unit, but what is the rest of the system?
m
l
August 17, 2011 6:01:39 PM
haha sorry, forgot to put the link in the question...
m
l
a b ) Power supply
August 17, 2011 6:02:01 PM
I don't believe there is that many good modular or semi modular PSU's under $70...
Tell us what case you have and what parts you have.
I have a list of great PSU's for around your budget but most are not modular...
heres a few I WOULD recommend but we really need your specs.
Antec HCG 520
XFX Core 550
Antec Neo Eco 520
Antec EA 500D
Seasonic S12II 520
Corsair CX 600 V2
I would recommend the Corsair TX-M and XFX Pro models (semi modular) and Seasonic X models but they're out of your budget....
m
l
a b ) Power supply
August 17, 2011 6:42:25 PM
Oh you dont have to worry about cable management in that case. All of the power supplies i linked above will work in that and not to mention, with some ingenuity, you can make it all clean and nice. Hell... you should see what my antec 300 got on the inside... it looks like a fricken squid in there.
m
l
August 17, 2011 6:54:00 PM
should i go with the corsair or the xfx?
m
l
Best solution
a b ) Power supply
August 17, 2011 6:57:37 PM
I'd take the XFX Model. Not bashing on corsair or anything, but it's generally a bit better than the newer corsair CX units.
August 17, 2011 7:07:22 PM
Best answer selected by skiunitkid.
m
l
August 17, 2011 7:07:27 PM
Alright thanks so much! You've been a real good help.
m
l
