FAQs: How to ask for build advice, Buyer\'s Guides and Troubleshooting
  • New Build
  • Buyer's Guides
  • HD
  • Systems
  • Product
Last response: in Systems
May 23, 2011 3:38:52 PM
Hi everyone,
So I'm upgrading my computer to this:
1. http://www.newegg.com/Product/Comb [...] mbo.638772
2. http://www.newegg.com/Product/Prod [...] 6820231277
3. http://www.newegg.com/Product/Prod [...] 6811129042
4. GPU = GTX 460
5. salvaging old HD/dvd drive
6. http://www.newegg.com/Product/Prod [...] 6817371016
from a HP m8100n.
So my question is will I benefit from additional RAM? On my HD I have 32 bit XP and I realize that I would have to upgrade to 64 bit to use the additional RAM. I plan on mainly using my computer to play Starcraft 2 and watch movies/tv shows/etc.
Also, I'm planning on buying a pimpass monitor so I can watch in HD until my ears bleed from the eyepoppin color. I need some suggestions.
Lastly, hows my build look? SC2 is coming with 2 more expansions in the future so am I future proof as possible (I anticipate they will come out 2012 at the latest)? Any other helpful bit of advice for a newbie?
Also, when I assemble all this, do I need to uninstall everything on my HD first (driver conflicts/etc).
THANKS
More about : faqs build advice buyer guides troubleshooting
May 23, 2011 11:50:36 PM
Your links are broken. Please see the build advice form in my signature and fill it out. Also edit your title to be more relevant. We need a budget especially. Get Windows 7 x64. Depending on how old/slow your HDD, I would most likely recommend replacing it - it'll bottleneck your system.
