Solved
What Is The Best PCI Slot Wireless Network Adapter Range & Speed Wise?
  • Connectivity
  • Wireless Network
  • PCI
  • Wireless Adapter
  • Wireless Networking
  • Product
Last response: in Wireless Networking
November 25, 2010 6:07:11 AM
Hello, I have been trying to find the best wireless adapter there is for my computer's PCI Slot. I'm not worrying about the price of it. I'm only focused on the overall range, speed, & connection stability. So, if you could lead me in the right direct of the leading edge cards in those aspects, that would be great.
Thanks, Con.
More about : pci slot wireless network adapter range speed wise
November 26, 2010 3:40:03 PM
Ok, thanks. I went with this adapter. (D-Link DWA-552 32-bit PCI Xtreme Desktop Adapter) http://www.newegg.com/Product/Product.aspx?Item=33-127-... But, I have another problem now. I can't figure out which of these antennas will give me better range? I'm trying to achieve the level of being able to pick up signals of neighboring houses.
D-Link ANT24-0230 Xtreme N 2.4GHz Antenna vs. D-Link ANT24-0700 2.4GHz Omni-Directional 7dBi Indoor Antenna?
m
l
November 26, 2010 7:42:44 PM
how fare away are you from the wireless of your neighbor?
are there a lot of walls?
m
l
November 26, 2010 8:00:28 PM
About 40-50 yards & one wall to the west. About 20-30 yards & two walls to the east. About 30-40 yards & one wall to the south. About 30-40 yards & four walls to the north.
m
l
Best solution
November 26, 2010 8:44:53 PM
If your neighbor has a N router, you might not need the additional antennas.
you can buy them and send them back if not needed.
November 28, 2010 5:28:20 AM
Bump...
m
l
November 28, 2010 3:53:27 PM
Best answer selected by CrusaderCon.
m
l
