Nvidia 8400 gs HDMI SPDIF Audio Cable
where can i buy a nvidia 8400 gs HDMI SPDIF Audio Cable from and my computer says i have no audio devices i don't no if it a driver problem or i need the cable because i looked at the card and it had no were to plug in a card or anything the only plug was the graphics cards fan.
5 answers Last reply
More about nvidia 8400 hdmi spdif audio cable
  1. if you don't have a 2-pin connector available on your audio card, you won't be able to connect the SPDIF cable,,, you would also want to verify that you have the pin outs on your motherboard - if you do have the pins available, cable is not hard to find, you would needs something like this http://www.pccables.com/05026.htm
    if you don't have pins available, I would say go with any 200 series nvidia card or higher that would fit your budget, they don't require the pins anymore as they have an internal connection and act as another sound card
  2. Question: Have you installed your motherboards audio drivers yet? The 8400 does NOT have a built in soundcard, so even if you connect it to the motherboard, until you get your onboard audio working, you will have no audio.
  3. he can have all the drivers he wants, but unless he has the spdif header connected if available, he won't get anything through HDMI.
    next best option will be to run the realtek HD drivers and connect PC by analog outputs to a multichannel input on receiver (but if you don't have that kind of receiver, you'll only get 2 channel stereo.
  4. ^^ Thats what I was referring to.
  5. Hi,
    I hope this will help few users that have run into the "no sound" or "no audio device" problem since installing an nvidia 8400GS card in their PC (especially if things were working fine before).
    I found on this forum: http://www.sevenforums.com/graphic-cards/135546-8400gs-kills-my-onboard-sound-output.html that disabling "search for other audio device" [than the onboard device] could work, however it did not work for me, worth a try though.
    For me, choosing "Use only default devices" in "sound and audio devices properties/Audio" (in control panel) did solve the problem (only make sure that your onboard device is selected as "Default device" in "Audio" and "Voice" tabs.
    Cheers,
    Rv
Sound Cards Audio Cable HDMI Nvidia Components
