Low Power HTPC: Please suggest components
I want to build a HTPC.
Approximate Purchase Date: this week
Budget Range: 300 After Rebates
System Usage from Most to Least Important: HTPC, some skype too :)
Parts Not Required: monitor, speakers, OS
Preferred Website(s) for Parts: amazon.com, newegg.com, superbiiz.com
Country of Origin: US
Parts Preferences: I would like to use
PURE Fusion Mini E350 (IPC-E350M1) http://www.sapphiretech.com/presentation/product/?leg=&psn=000102&pid=1034 and my existing HT setup of Onkyo receiver, 55" Samsung LCD, Niles IR receiver (all HT stuff are in closet about 50 feet from my primary TV)
Overclocking: No
SLI or Crossfire: Maybe (if that is possible)
Monitor Resolution: 1080p
Additional Comments: As mentioned above, my HT stuff is about 50 feet away from my primary TV and I use Niles IR transmitter/receiver to control it.
I need guidance on the following components:
- 4GB RAM
- Nice case (with or without external brick power adapter)
- HDD about 80gb (required only for OS, as I will be using my NAS)
- Blu-ray drive
- TV tuner and PVR (this will be very helpful/useful)
- IR Remote (with keyboard if possible)
TIA
~mys
19 answers Last reply
More about power htpc suggest components
  1. I think you are right that the AMD fusion is the way to go
    RAM choice wont be crititical , just buy some reasonable quality 1333 MHz RAM which will be cheaper and clock to board speed anyway . Id buy on price rather than anything else .
    Over kill for a mini ITX but I like the silverstone Grandia 04 or 05 . They accept m-atx boards too which might open up your choices a little . Dropping the fan speeds makes them totally silent .
    The smallest capacity WD Green hard drive . An 80 gig drive is likely to be older technology and relatively noisy .
  2. My Signup,
    For a low power HTPC the i3 2100T is an excellent option. See the link below comparing the E350 with the i3.
    http://www.xbitlabs.com/articles/cpu/display/core-i3-2100t.html
    The i3 will support video encoding and general PC tasks that the E350 simply cannot. It is however MORE expensive.
    Below is a suggested build for the HTPC (Approx $440).
    hec Black 0.7mm Thickness SECC Steel 7K09BBA30FNRX Micro ATX Media Center 300W Power Supply / HTPC Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811121100
    Intel Core i3-2100T Sandy Bridge 2.5GHz 2 x 256KB L2 Cache 3MB L3 Cache LGA 1155 35W Dual-Core Desktop Processor BX80623I32100T
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116394
    MSI H61M-E33 (B3) LGA 1155 Intel H61 HDMI Micro ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130588
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
    SAMSUNG Black 12X BD-ROM 16X DVD-/+R 48X CD-ROM SATA Internal Blu-ray Drive Model SH-B123L/RSBP LightScribe Support (Retail)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
    SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152244
    IOGEAR GKM561R Black 2.4GHz Wireless HTPC Multimedia Keyboard with Laser Trackball and Scroll Wheel
    http://www.newegg.com/Product/Product.aspx?Item=N82E16823176018
    This is a nice build all with quality components. I don't know about a TV tunner but basically add the one you want. Hope this helps. Perhaps other more experienced forum participants can comment since I am admittedly still learning.
  3. Silverstone case seems to be big, anything smaller that you can suggest...
  4. lifeking said:
    My Signup,
    Thanks for taking your time. The above config seems to be very good, but I afraid I am locked to AMD E350. I got the Sapphire listed/linked in the OP for a very good price $91 over the weekend...
  5. Take out the MB $70 and cpu $134 (-$200) and change the case for the one below.
    It evens puts you under budget (total ~$240). That gives you $60 for the tunner.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811121115
  6. Thanks a lot.
    Does the TV tuner allow me to record/timeshift the programs and how about this case http://www.amazon.com/MI-008-Tower-Black-Chassis-Supply/dp/B001H0BA24/ref=sr_1_fkmr0_3?ie=UTF8&qid=1306203435&sr=8-3-fkmr0 ?
    ~mys
  7. TV Tunner works with Windows Media Center which should take care of the recording. I think it should be ok but I have never installed one myself. Several reviews on newegg mention that it works well with media center. Perhaps another poster can help with your question.
    The case looks good... The only potential issue I can forsee is the size for the Blu Ray drive. Look up the size of the drive on the Samsung website to see if it fits. The case has good price/reviews.
  8. The sapphire MB only supports 2 slots SO-DIMM DDR3 800/1066 Single Channel modules, will the G-SKILL ram (dual channel) work?
  9. Yep - it will work.
  10. lifeking said:
    Yep - it will work.
    Super!!!
    lifeking said:
    Yep - it will work.
    Hang on a minute, your motherboard uses SO-DIMM DDR3 (laptop size RAM). The G.Skill RAM listed above is desktop sized RAM. You'll need a 2x2GB RAM kit like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231340
    or a single 4GB stick like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820147068
    BTW, I can confirm that Zacate boards use 1333 DDR3 memory just fine at 1333 speed.
    Thanks for noting the diff between the memory types, also I have been drooling/looking at your setup and putting together of it at http://s179.photobucket.com/albums/w319/rwpritchett/HTPC/HTPC%20Nirvana/. The link to the memory used by you doesn't seem to go to the right place.
    Can you tell me if the TV Tuner http://www.hauppauge.com/site/products/data_hvr1250.html will fit and work in the sapphire MB which has the following expansion slots (1 x PCI Express 2.0 x16 slots, 1 x MINI PCI-E x1 slots)
  13. The memory I used is desktop sized RAM, so it won't work for you anyway.
    For the TV tuner, the 1250 is an excellent choice and will work just fine in the PCIe-16x slot. The Mini PCIe on your board is for a small WiFi or similar expansion card and will not work with full size PCIe cards.
    If your budget allows, it's quite handy to have a dual tuner because they allow you to watch one channel while recording another. There are three popular ones to choose from
    HDHomerun Dual ($125)
    Hauppauge HVR-2250 ($110)
    AVerMedia A188 Duet ($70)
    Note- you never said what country you are in. All of the tuners mentioned so far are good for ATSC and clear-QAM in the US. You may need to look further into you local TV broadcast standards if you are in UK, Australia, or another area.
    If you need any insight to my own Zacate HTPC experiences, feel free to ask.
  14. Will this memory https://www.superbiiz.com/detail.php?name=D3-13S4GSP&title=Super-Talent-DDR3-1333-SODIMM-4GB-256Mx8-Spectek-Chip-Notebook-Memory work with my MB which requires O-DIMM DDR3 800/1066 Single Channel modules?
    TIA
    ~mys
    TIA
    ~mys
    Spec-wise, that memory will work with your motherboard. You may want to check with Sapphire to see if it is on their memory QVL (qualified vendor list). I can't seem to find the QVL on their website.
  16. rwpritchett - Good catch on the RAM. Sorry mysignup... Good luck on the build.
    If you can do post the results and how everything works.
New Build Systems Product
