Gpu , monitor and case help
Last response: in Components
haf x
580...works almost as well as the 590, its cheaper, and if u buy another 1 in the future for sli itll work twice as good as the 590 (which is built in sli)
definitely ignore the dell and the eizo...i think your best bet is the zr24w. Go to newegg.com to look for cheaper ones as well.
If you plan to game in 3d your monitor has to be 120Hz, ~all of those are 60.
Good luck with your build and ask if you need more help :)
Then I'd go with the cheapest one. They're all 24"...I paid about $150 for mine (Dell), 24", and it works perfectly. I'm a software engineer so I spend a lot of time with photo editing and multimedia as well...you might be better off just by going to Target and checking the monitors they have there.
It doesn't really seem like money's an issue for you...if so, go with the Dell. You'll have a good warranty plus an excellent monitor.
Ask the community
