Hi,
I just finished assembling a new PC for myself using a brand new boxed i5 2500K and Gigabyte GA-Z68X-UD3H-B3 (rev. 1.3) board with some Samsung DDR3 ram. I am using my old 550W PSU (Ultra LSP) from my working system (where the PSU still works). Now when I try to power on the system I get no response at all.
I tried plugging in the PSU into my old PC and it would boot just fine... I tried using the new case with my old PC to check out the power switch and that too works fine. The tech support for the store I bought from thinks it could be motherboard and wanted me to exchange it, but I was wondering if it could be the CPU or PSU itself. Does anyone know what could be the issue in my case.
More details:
My old PC was a AMD Sempron chip with some equally old Nvidia graphics with at least 4 HDDs connected and never had any issue with the PSU (Which was replaced around 2 years ago).
In the new setup, I installed CoolerMaster Hyper 212+ on the new 2500K and have 2 sticks of 4GB samsung memory (brand new).. I also did a breadboarding test with no luck.
I will be heading to the store (1 hour drive each way) to get the motherboard exchanged, but was wondering if I should have them somehow check the CPU and PSU as well.. depending on your feedback, I'll insist on it.
TIA
More details:
TIA
