Closed
Pci e x16 running at x4 (asrock z77 pro3)
Graphics card Authority
Motherboard Authority
put your card in first pci-e slot then press the ? on gpu-z you will see her work at it specs speed this is a power saving features on some amd graphic card post the result back
thanks for reply,
that now on first pcie slot (cpu below) but still x4 even running render test in gpu-z
Related ressources
Best solution
then she is working 4x at 2.o and give full power on load this is a kind of power saving device on the card and the motherboard
Ask the community
