Solved
New Replacement MoBo problem
Last response: in Systems
May 25, 2011 8:37:06 PM
A friend brought me his computer because it wouldn't boot.
After inspection, I found a ruptured capacitor on the motherboard.
He purchased a new Foxconn, M61PMV to replace his old ABit.
After clearing out the case I installed the new motherboard, CPU and HSF,
Outside of the case, and all I got was the HSF spins for about 7 seconds and
then the system shuts down. To get it to start again I have to unplug the PSU
and wait about 5 minutes, then when I plug it back in I get the same results.
I have tried it in the case with the same results.
Nothing but the HSF and PSU is connected.
I have gone over all the tips at http://www.tomshardware.com/forum/261145-31-perform-ste...
to no avail.
I have swapped out the PSU for a different one, with the same results,
and I have tested the PSU for correct voltages.
I am assuming at this point it is likely the motherboard, however I do not
have another CPU to test with.
Any help would be appreciated.
Best solution
a b B Homebuilt system
May 25, 2011 8:50:50 PM
You could try unplugging the power switch header and starting the PC manually... I once had a faulty power switch cause me a lot of trouble lol.
Other than that, it sounds like a mobo to me.
May 26, 2011 2:09:24 AM
Honestly I did not think of trying that.
I will try it now and post back results.
TY for your quick reply
m
l
May 26, 2011 2:18:18 AM
You are a gentleman and a scholar!
It was the power switch. I shorted the jumper and
it booted right up. So I added a old switch and
voila boot success.
I thank you!!
m
l
May 26, 2011 2:18:31 AM
Best answer selected by Spectre Nexus.
m
l
