i really don't know much. but i setup a desktop with below specifications to work at home. not for gaming. just running lot of CAD software n some virtual machine.
bought a : Corsair CMZ 8G X3M2A 1600C9 (suppose a 2 x 4GB DDR3, dual channel, 1600MHz / vengeance)
CPU : i5, 2400
Motherboard : ASUS P8B75-M LE (Chipset B75) the lowest end of ASUS i think
BIOS : American Megatrends Inc. ver. 0307
BIOS setting on memory speed : Auto
graphics : gigabyte NVIDIA GeForce GT 430, 2GB, 1600MHz (since 1600, should be not a factor of system RAM drop right? or does it even affecting?)
PROBLEM : why my CPUZ shows 'max bandwidth' at 667MHz only. should hav been 800MHz right even though BIOS set it to 667Mhz right? (since it's the 1600Mhz written on product should be the Max)
1. not gonna overclock my RAM since it will increase the voltage. or should i?
2. just want it to be optimized to it's normal speed.
3. what is XMP actually?
4. how do i read the memory timing?
5. what is really my RAM normal voltage 1.50V or 1.65V? (non exact model on latest QVL)
CPU : i5, 2400
