So I just got all my parts for a new build from newegg which are as follows:
mobo - MSI p67a-c43
ram - g skill value series pc 1333 - (2 x 4gb)
video card - sapphire radeon hd 5770 1 gb
cpu - intel i5 2500k sandy bridge
cooler - coolmaster hyper 212
I used the following from an old buid:
Antec 300 case
Corsair TX 750 watt power supply
old hard-drive and old DVD burner.
So, I installed all the new parts. I plugged in the power supply (normally on my old build when I would plug in my power supply the system would make a "woosh" type of noise) and I got no "woosh". I turned on the PC and for maybe 0.5 seconds all the case fans, cpu fan, and psu fan would turn on and the video card "S" on the side would light up... then it would all shut off. If I would try to power it up again... nothing. If I unplug the power supply and replug in the power supply and then turn the PC back on I will get the same 0.5 second turn on and turn off and then nothing if I try hitting the power button again.
I am wondering if it is a power supply compatibility issue or a bad mobo? Looking for an idea or advice as to what the problem may be. I was hoping for some good ol' memorial day weekend gaming, but looks like those plans may be foiled.
Anyways, any help would be greatly appreciated!
Edit - I have also tried taking out one stick of ram to see if that was an issue, but still the same problem as above with just one stick of ram in.
mobo - MSI p67a-c43
Antec 300 case
