Are all of my parts good?
Last response: in Systems
May 26, 2011 2:05:42 AM
OK so i have done probably about 40 hours of research over the past year getting into building my first computer, and my budget is 2000, i believe i have picked all compatible parts and i will upgrade during the summer because i will have some more money. Please tell me if all my things are right, i already know how to build a computer, just asking for help if everything is good. Thanks.
More about : parts good
May 26, 2011 2:10:48 AM
I don't see any parts... Fill out the build advice sticky for the best help.
m
l
May 26, 2011 2:17:07 AM
My parts are as follows:
Intel Core I7 2600k and 8gb ddr3 1866 mhz ram: http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
HAF X Case: http://wonderelectronics.amazonwebstore.com/HAF-X-ULTIM...
Corsair AX 1200W: http://www.circuitsnthings.com/index.php?option=com_vir...
EVGA GTX 580 SC: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Asus Maximus IV Extreme: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
My Boot Drive. 128gb vertex 3 ocz ssd: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Plextor Blu Ray multi awesome burner: http://www.circuitsnthings.com/index.php?option=com_vir...
CoolIt Eco ALC 240 mm kit: http://www.avadirect.com/product_details_parts.asp?PRID...
I am getting the water cooling later so it doesnt add to total. I will add a couple of fans also.
Total about 2000
m
l
May 26, 2011 2:39:37 AM
yeah its high end........but spending that much......if u r only gaming ....its overkilll........it could be around 500$ less......also i see no lcd mentions.........if u have it wht r the resolutions????
m
l
May 26, 2011 6:04:57 PM
i have a 1920x1200 or watever resolution monitor, and ima host a server for minecraft, some video editing and i want high end for gaming because i want like 40 fps on metro 2033 ultra high settings with fraps on. I will be doing alot of videos and stuff. I will be upgrading to sli gtx 580 sc later on, which will allow me to get a better monitor still with awesome fps. and i like overkill...
m
l
