G
Guest
Guest
Hi all, I'm having some problem playing mp3s in win2k, hope you guys can give me a hand.
The speakers are giving me static noises and even cracking sound when I use my windows while playing mp3s with winamp. For example, it gives me static noises when I click on start button, when I right click to access menus, and even cracking sound when I minimize, maximize, scroll, and navigate graphics intensive websites. Sometimes the songs even skip!! (yes, the songs are in the harddrive, not CD, and there's nothing wrong with the mp3 files)
I have exchanged speakers with my roommate, same problem.
I have exchanged soundcard with my roommate (same soundcard), same problem on my computer, but everything fine on his.
So I have concluded the problem is not my speakers & soundcard. Since my roommate is using win2k, i thought maybe it's a win2k issue. I have a PCI voodoo4 sharing the same IRQ with my SB Live! (IRQ 11), so I thought maybe that is the problem. But my other friend has a dell machine using win2k, his system is setup having his Rage 128 Pro sharing the same IRQ (9) with his SoundMax soundcard.
I am using the ECS K7S5A motherboard, and I have already disabled the onboard soundcard.
Has anyone experienced similar problem before? What could be the cause?
Thank you guys so much!!
