Hi Community,
I have a Buffalo WHR-HP-G54 router and my wireless connectivity is being selective on which devices it distributes wireless to. For instance, my laptop will not receive any wireless signal (continues to say "Identifying" on Windows 7 but can see that the router is broadcasting), but my iPhone (which is right next to the laptop) will be able to connect to the router without any issue. I have about 5-6 devices that connect to the router wirelessly, and 2 out of the 5 usually do not receive any connection unless I reset the router through my desktop which is connected through an ethernet cable. Is there a possible solution to this without having to factory reset the router? I do have quite a bit of ports forwarded already and would be much better for me if I did not have to setup the router again.
Also, I know that my router is capable of using the dd-wrt custom firmware, but is NOT using that firmware. In addition, I did buy a D-Link DIR-655 router which remains unopened. If I can get the old Buffalo router working again, then I will be returning this router as I would have no need for it. Any help or info would be much appreciated.
Thank you.
Thank you.
