Hi Guys,
I ll post my problem here, because it is very similar.
I just upgraded with new MB, CPU and RAM and it doesnt boot up at all.
MB is the same as the previous person: BIOSTAR TZ77A
Cpu is: i5-3570K
The ram is: Corsair Vengeance 4 x 4GB PC15000 DDR3 1866MHz CL9 .
PSU: ULTRA 550w, CORSAIR 450w (tried with both).
And yep, I know it is not on the memory supported list. In the rush I skipped checking. Still I'm hoping its compatable.
So the problem is the system doesnt want to power on at all. Just the fans move for parts of the second.
I tried (possibly) all combinations. 4 sims inserted, 2, 1. When 2 in the white, in the red, or 2 by 2. Anything.
The mem is 1.5v.
Since the system doesnt boot up at all, and the sound doesnt give any error code, I really dont have much what to do with it.
No bios updates, no playing with voltages.
I really need to know fast which one is the faulty hardware (or incompatable), to see what to do with these parts. Return, buy new, or what ...
Needless to say, its frustrating to spend 700$ on parts that do not work.
Sent an email to Biostar support, but I doubt it they ll give me some precise info.
p.s. I attempted to boot with only CPU and RAM, plugged montitor to one of the onboard video ports.
Even tried without plugged in monitor at all. MB should still boot up. Not sure if there is no RAM modules at all. Should the system power on?
I am considering buying cheap DDR3 ram, just for testing. Something around 20-40$.
Ill probably do it. But there is no guarantee it will work either.
Also another small concern is,
Even if these MB are brand new, with Z77 chipset, is it possible to be specifically flashed with bios for generation 2 - sandy bridge.
On the MB website says that they support by default ivy bridge, and with a BIOS flash, they would support sandy bridge.
But is it possible, these specific 1st MBs that are on the market, to be the opposite. And be flashed with another bios for generation 2. On tiger direct website, in the description, they say it supports Genration 2 - Sandy bridge.
But on the other hand, in the MB manual, and even printed with big letters on the board itself, says 22micr CPU.
I bought MB & CPU, just 2 days after ivy bridge came out, this is my concern.
Another info,
I did a small research. It appears that my RAM, defaults to 1333mhz and certain default voltage when initialy boot up.
To prevent incompatabilities. Then only manually it is set differently.
This is at least something ....
Many thanks for the help in advance. I am building systems for 20 years now. And I knew it in advance that you never know with new hardware.
... and also when you a striving for the cheaper solution ... that makes things harder also. (thinking the MB here)
Cpu is: i5-3570K
The mem is 1.5v.
Another info,
