WEIRD errors happening please help
I don't know how to explain the problem very well.
Basically, I'll be browsing the net, or even just doing homework on word or excel, and the computer will start to act funky. First it will freeze, from 5 - 30 seconds, mouse doesn't move, can't ctrl alt dlt, can't alt f4, nothin. When things snap back out of freeze mode, sometimes the mouse icon gets all funky, like normally if a hyperlink is hovered over it turns into a hand right? well it'll be a I cursor or it might be an old school looking hand that's all 8 bit.
It will freeze again, and usually the 2nd time it wont come undone and I usually reset my computer at this point.
What the HECK is going on folks?
Windows 7 home premium
6.1.7601 service pack 1 build 7601
x64
i52500k
BIOS version/date American Megatrends Inc. v1.11, 4/14/2011
SMBIOS version 2.7
8gigs ddr3
NVIDIA GeForce GTX 560ti
System temps are fine.
I just have spybot and avg are those sufficient? I also have cc cleaner.
Computer has not been having this specific problem since day 1, been up about a year now, various little problems have come and gone, this one has stuck for 2 months now.
4 answers Last reply
More about weird errors happening help
  1. Have you downloaded some stuff on net ?
  2. i recommend you put this inside win7 fourm
  3. Start here...
    Run #1 and than #2 @ Simple and free guide to removing malware
Motherboards
