Hi folks. A friend of mine built me a new HTPC with the aim of having smooth iso file 1080p playback & full codec HD audio. Here is the spec list:
Hardware
AMD Athlon 64 X2 7550 Bundle including AMD Athlon 64 X2 7550 AMD Processor, Asrock AM2+ N68C-S UCC mATX Motherboard and Heatsink and Fan
Inno3D GT 430 1GB SDDR3 DVI VGA HDMI Out PCI-E Graphics Card
Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 Memory Kit CL5 1.8V
WD 250GB 3.5" SATA 6Gb/s Caviar Blue Hard Drive - 7200RPM 16MB Cache
Linked via 1.3 HDMI lead to my Yamaha RX-V1900 -> Panasonic AE-4000 projector.
Software
Window Media Centre
Arcsoft Total Media Theatre 5
All drivers up to date, correct software settings. Using 2m HDMI lead to my amp.
The problem
No probs at all with video - projector display is 1080p 24fps. However, after selecting the movie, when it starts, the Yamaha display is PCM uncompressed. This is despite setting the default audio device to be the Nvidia graphics card and selecting "Use primary audio source only". The only method which has worked occasionally is by switching the input on the receiver to something else then back to my PC input again to get the HDMI handshake - this results in DTS-HD Master Audio or True HD etc.... but only sometimes. Usually the picture just freezes and I have to start from scratch.
I've racked my brains and torn my hair trying to reset the settings... I'm wondering whether I have a dodgy HDMI lead but I feel that's clutching at straws.
Any ideas please????
Thanks!
Hardware
Software
Window Media Centre
The problem
Thanks!
