Solved
Is this power supply any good?
  • Power Supplies
  • Components
  • Product
Last response: in Components
August 22, 2011 12:15:56 PM
I bought this power supply and im wondering is it good, a family member tested it out with a paper clip on both ends and it turned on, but it was too big for my PC because it was a slimline. So does anyone have this and is it good. or should i buy another one.
More about : power supply good
a c 243 ) Power supply
August 22, 2011 12:43:42 PM
It cost $16 and you want to know if it's good ? :heink:
It's a piece of crap, 480 watts, a single 18 amp 12v rail, litle red voltage switch :lol:  :lol:  :lol:
It doesn't fit your machine :non:
Yes, you should buy another one, it's going to cost you more to get a decent psu and since you need a slimline you'll need to measure what you've got and do some research before buying another one
Here's an example of a good power supply
m
l
August 22, 2011 1:31:42 PM
im going to build a pc with a mid-tower case and i already got a video card. but i guess no more this power supply
here is my build that i am soon going to buy
mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
ram(x2)- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
case- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
processor- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
fan for processor- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
cd/dvd drive- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
psu-??
m
l
August 22, 2011 1:42:32 PM
can you recommend me a power supply under 35 dollars but above 450 watts
m
l
August 22, 2011 2:31:58 PM
No, sorry
It usually helps if we know your video card.
At $40 this 380 watt Antec with a combined 12v output of 28 amps is much more powerful than the pos you had linked, the fact that it has a pcie power connector means it can handle more powerful cards without the use of an adapter, and is as cheap as I'm willing to reccomend
m
l
Best solution
a b ) Power supply
August 22, 2011 5:47:38 PM
September 3, 2011 2:38:02 AM
Best answer selected by ultra619.
m
l
