Will my ram work with this motherboard?
will Kingston 8GB KIT DDR3 1600MHz CL9 HyperX X2 Grey Series work with Gigabyte GA-880GM-USB3? because the ram says it has 1.65v and the motherboard says it supports 1.5V so will it work or it wont? if it wont please suggest me motherboard in its value with am3+ thank you in advance
1 answer Last reply
More about will work motherboard
  1. It will probably be fine, but in general you should try to buy memory running at the standard 1.5 volts. That kit also looks pretty damn unimpressive. I've got a cheap kit of DDR3-1333 that runs at 1600 with lower voltage and tighter timings. Cost me $45 last year.
    I'd recommend picking a better memory kit. Find something with tighter timings and standard voltage.
Memory RAM Motherboards
