Closed
Heavy Problems
Well.....
I just got my new mainboard as my old one was making alot of trouble, but now I got the real deal of trouble.
First the PC needed like 20 tries to even start up with the old OS, then it gave me about 30 error messages of all varieties of kinds and pretty much all of my programs weren't working anymore, neither after 3 further boots.
Okay so I told myself just reinstall your windows, well after about 2 hours of messing with the pc that didn't want to load the setup, i got to "windows is loading files" which i am stuck in for 6 hours now, the line is moving, but about 1 inch per 3 hours, and it would probably take 2 days to just finish loading the files and I'm pretty sure after that I would just get an error message.
So what can I do? I checked my ram with memtest86 1 week ago, so that shouldn't be it, nor the windows disk, i switched the Rom and the HDD to different SATA connections, no effect.
I cleared the CMOS, no effect.
I'm really desperate right now, I just want to reinstall windows but something is going so horrible, behind every imagination wrong that I can't even explain it.
I hope someone in here still knows what my problem may be and what the solution might be.
/Edit forgot to post my specs
Intel i5 2500k
8gb DDR 1333mhz Corsair
ASUS EAH5870
Western Digital 750 GB HD
Gigabyte Z68XP-UD3P
BD-Rom (Sata)
More about : heavy problems
Just so you know, when I got into the old OS and clicked away all those error messages, I installed the mainboard drivers from the CD, and after that all the trouble really started, kept going w/e.
Motherboard Authority
What is the current hardware that you are trying to make work, what was the motherboard that went bad, which os are you trying to install/repair and 32 bit or 64 bit.
Related ressources
Old Mainboard: ASRock z68 Extreme3 Gen3
Old AND new Windows: Windows 7 Professional 64-bit
Didn't change anything but the mainboard, the old one made my PC Crash and Freeze all the time, and after 2 Threads here in this forum everyone seemed to be sure it has to be the mainboard, and hey, I had no crashes with the new mainboard yet, allthough I never really was in windows for a longer time ;)
Removed all but one of my 2gb Ram bars and tried it again, no effect, again stuck in Windows is loading files, and everything takes ages, the bootup screen stays for ages, the loading os and the following boot from cd/dvd takes ages and then i get stuck.
What is a "clean install"?
I don't know a different way to install windows than inserting the disc and following the setup o.O
If you mean to remove everything thats on the hd, well thats what I want to do, but if you read what i posted above I don't get to the point where I can select that stuff, i get stuck in Windows is loading files...
Motherboard Master
OK, I thought u just connected the old HDD with the old windows on it to the new system.
Clean install is HDD erase and brand new install.
Well I did connected the new mainboard into the old system including the old hdd, but I want to reinstall the complete os as a clean install, yet I get stuck before I get to the actual setup.
Uhm, my monitor is connected via DVI to my GPU (The asus, not the onboard one)
Yes I can get into bios, after a while I can even get into the old OS but i get 20+ error messages saying that all programs stopped working and a few other windows error codes and whatnot.
Only problem is that the windows setup is not working and I cant do a system swipe, but at the same time, using the old OS is not an option either as nothing is working and I keep getting spammed with error messages and the only program left working is spotify lol, and even that one is broken every second boot.
Motherboard Master
OK so what happened when u select to boot from the CD/DVD first?
Don't use the GPU card, use the iGPU after u enable it in the BIOS.
Try that.
I only have that one HD
Why should I use the internal GPU? The gpu never made any troubles and do you really think that the gpu could cause the setup to make problems?
I might try to put my windows from the cd on a usb stick and try to install it from there, worth a shot innit?
Mate, no offence but you really have to read my posts more carefully you keep misunderstanding what im saying.
DRAMATIC change of events, I can now not get into the old OS anymore, as when i log in, my explorer now is one of the programs that is not working anymore and just keeps crashing/restarting every second, I can still get into safe mode without any error messages yet, I then tried to uninstall some of the drivers of the old mainboard but it tells me that the windows installation manager is not correclty installed (oh the irony).
So now I can neither reformat my pc (delete everything and reinstall windows) nor can I enter the old OS.
Motherboard Master
I understand what are u saying.
Why don't u pop in the disc or USB and and your problem with clean install?
Why are u talking about the old system???
Do u need to salvage any data from there? If no, erase and install.
I now got 2 error messages, one if from the program spotify so that has nothing to do with my system, the other one is from "runonce.exe", I will just post the error code here:
"Die Anweisung in 0x7258f23f verweist auf Speicher 0xffffff85. Der Vorgang read konnte nicht im Speicher durchgeführt werden."
I'm sorry that the message is in german but I'm from Austria and the language of the OS when I installed it in January was german >.<
Ok, for the last time
I can still access the old installed OS as I !!! CAN NOT !!! install windows again as I get stuck before I get to the actual setup of windows.
Got it now? I CAN NOT INSTALL WINDOWS I GET STUCK IN THE PROGRESS.
Nor can I get into the old system do actually do anything as my mouse and keyboard stop working after a few minutes and till then the explorer just keeps crashing and restarting every second so the only thing I can do is click away all the error messages I get when I boot into the old OS, which takes like 5 reboots to actually not get stuck somewhere inbetween the booting.
Sry for me beeing mad but my pc kept crashing for the last 4 months and now that I got my new mainboard nothing works at all and I sit here, and watch my ******* money flying out the window for nothing, I could just aswell burn it.
So I hope you understand why I'm incredibly mad and desperate at the same time.
Motherboard Master
Its hard to help u, if I don't know what u doing.
Did u read my last post before this one?
What are u trying to accomplish? The more detail, the better : )
I want to do a clean-install of windows, but I can't as I get stuck in "Windows is loading files..."
Well I would be happy if the old OS was working atleast but it doesn't.
I got all my data from the HD so I WANT to erase it all and reinstall windows, but it just doesn't work.
Erm, Its a Corsair 1333MHZ DDR3 Ram
4 modules @ 2 GB
says something like XMS3 on them
PSU = Coolermaster GX Lite 700W
/Edit
RAM = Corsair CM3X2G1333C9 1.50V vers.2.1 09220109
9-9-9-24
1333 MHZ
2048 MB
XMS3-1333
Thats whats standing on the back of the modules.
Motherboard Master
When I helped some people and we solved the issue, it was the RAM or PSU in most cases.
W7 install is more sensitive than any other windows before.
That is why I thought to remove the GPU and use the iGPU instead, as it would use much les power and it could finish the install.
If u could swap the PSU with another, that would help.
Sometimes just helps to use the USB for the install media and it works too.
Could be a few different things.
Motherboard Master
Waddap said:
I already tried it with only 1 and 2 bars of the ram in it, no change.
And those 2 sticks, did u had it in the 2nd and 4th slot from the CPU?
1) I switched the SATA ports - no change
2) What is ahci mode?
3) I need an iso file to put in that program for the usb thingy, how do i get that? my alcohol is just turning it into an mds :S
Motherboard Master
Win 7 take advantage of this and u can see it in Integrated Peripherals in the BIOS.
Configures the SATA controllers to AHCI mode. Advanced Host Controller Interface
(AHCI) is an interface specification that allows the storage driver to enable advanced
Serial ATA features such as Native Command Queuing and hot plug.
Ask the community
