Hey everyone! So, I just built a computer with the following components:
CPU: Amd Phenom II X4 840 95W
Motherboard: ASRock M3A770DE
Graphics Card: XFX Radeon HD 6870
RAM: Corsair XMS3 DDR3 PC10666/1333MHz CL9 2x4GB (CMX8GX3M2A1333C9)
Power Supply Unit: Corsair CMPSU-650TXV2 650W
DVD-Burner: Sony Optiarc AD-5260S
Harddrive: Seagate Barracuda 7200.12 ST3500413AS 16MB 500GB
So, first of all it wouldn't boot at all, but that was because the 4-pin connector was incorrectly 'installed' into the motherboard. Speaking of which, the motherboard supports an 8-pin connector but I only have 4-pin connectors (two of them). Should I use two 4-pin connectors or only one? Moving on! When I got the PC running, I directly bumped into another problem, the monitor didn't detect any signal. The monitor got HDMI, VGA and DVI. I've had this problem before when I upgraded my own computer, but the solution to that was that the 8-pin connector to the psu was kinda loose (problem solved in tom's hardware, thanks!). So it's not the same problem.
So here are some things I've tried: (I can't remember all of them )
Switching the graphics card into a slower (Radeon HD 5450) which didn't use any connectors from the psu, didn't change anything.
Moving the graphics card from a red PCIe 2.0 crossfire bridge into a red one, didn't change anything either (except that I might broke the green one )
Disconnecting the wires from the harddrive and the dvd-burner, didn't change anything either.
Using a VGA connector. Using a DVI connector. Using a HDMI connector. Connecting an HDMI wire in the computer an then connecting to the screen through a DVI adapter.
Tom's hardware
Also, when the PC is booted and running, all leds are working and the fans are spinning but I can't open the DVD-burner
Please, any suggestion will be appreciated. Please help me!
Tom's hardware
.. oh snap!
