Direct cable connection
I need a quick primer on a direct parallel connection using only the parallel ports and the configuration of the cable. Do I need to cross some wires to make it work, or just a adapter to have two male ends? Any comments or links would be useful. I used to be able to do it with USB on my MSI rig but my power supply took a dump and I dont have the means to get it done quick enough. thanks
You Dont Want To Be The Last to Know Anything.
3 answers Last reply
More about direct cable connection
  1. You will need this:
    <A HREF="http://invalid.ed.ntnu.no/~kamben/hwb/ca_InterLink.html" target="_new">http://invalid.ed.ntnu.no/~kamben/hwb/ca_InterLink.html</A>
    Though it might be cheaper and easier to just get 2 network cards and a crossover cable. That would be insanely faster too.
    <A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
  2. nah, you could build that for about 5 bucks, assuming you already have some cables you could use, a soldering iron and solder, and a little skill of course.
    this is my boomstick!
  3. Thanks for the replies guys Im going to start a new thread. I have a different idea.
Connection Cable Networking
