Solved
Power Supply Confusion
  • Power Supplies
  • Computers
  • Components
  • Product
Last response: in Components
August 24, 2011 12:29:54 AM
So, I was looking around for a new power supply for my computer. I've been using this old one that came with my hp computer. I think it has a 350w rating, but I believe my +12v only has a rating of 280w or so. Regardless, I've done some tests, the online ones that tell you approx how much wattage you need to support your computer and its parts, and it recommends at least 387w D: Now, the computer runs fine, but soon I'll be upgrading my mobo, and installing a amd phenom ii x4 955 be and 2 sticks of g skill DDR3 10666 ram. Anyways, I was looking around for an upgrade and I found what appeared to be a deal, however, I just wanted the community's feedback. The product is a Thermaltake 600W 80 Plus Bronze Certified Power Supply (TR-600P) The product is currently going for $49.99 +tax. I'm having problems finding reviews so any feedback would be much obliged. Thank you guys in advance :)
More about : power supply confusion
a b ) Power supply
August 24, 2011 2:28:09 AM
Unfortunately cheap PSUs are low quality and unreliable. They tend to fail frequently. Seasonic and PC Power and Cooling are the PSUs at the top of my shopping list.
m
l
a b ) Power supply
August 24, 2011 4:18:25 AM
Do you know the form factor of the PSU?
m
l
August 24, 2011 7:46:00 AM
Well, I'm looking for an matx format and I live in canada sadly, so most of the stuff on newegg costs about an extra 10 bucks or more for shipping:(  But I think the antec neo eco series has fee shipping currently :D  On a side note, what do you guys think of the Antec VP450? It was manufactured by fortron I think but it's an older dual +12v rail design with 18 A per rail.
m
l
Best solution
a b ) Power supply
August 24, 2011 8:12:52 AM
neo eco is based on the seasonic s12Ii series. The HCG 520 is also based on a seasonic model that i can't quit e remember...
I'd only take the VP if Antec HCG, Antec Neo Eco,Antec EA ,Antec EA Green is not available.
August 24, 2011 4:46:50 PM
Alright, I found on newegg the anter neo eco 520 for 59.99 plus tax with free shipping :D  Thanks for your posts and replies guys.
m
l
August 24, 2011 4:47:03 PM
Best answer selected by Ferny111.
m
l
