Hi guys, I would like to know that the faster fan speed of the ATI Overdrive will keep my Graphic Card cooler?
Or it will not make any diffrent?
And what is the safe temperature for my Graphic Card?
THX Guys...
70c to 80c should be fine when under full load but i'd expect the temperature should be lower than that if you're using non-reference cooler. for the fan speed you can use CCC or MSI after burner to control the fan speed.
