Gtx 480 power
Hey, so I have an Alienware Aurora R2 and I want to get a second gtx 480. I was wondering if my 850w Psu can handle two gtx480s. I do HAVE the required plugs one six pin and one 8 pin but I do not want to hurt my Psu in doing this. Any help would be greatly appreciated thank you.
6 answers Last reply
More about power
  1. The GTX480 video card consumes a ridiculous amount of power and in SLi, the temperature issues will only increase, this card is already enough to run any game on high settings at a nice resolution so why get another? Dell power supplies are usually low-quality; Can you search for how many watts are on the 12-volt rail(s) please, there should be a sticker on the power supply in your case.
  2. Try to find out how many amps you have on the +12v rails, then google "power supply calculator" and pick a calculator. You might want to try a few out. Newegg has one listed in the search results and it wasn't as thorough as I would like, but it said that I would need 1,017 Watts for 2 GTX 480s. So you might find that you need a new PSU with a lot of amperage.
  3. Delta built , 80+ rated and 825 watts combined on the 12v rails, shouldn't have a problem with a pair of 480's.
    That's a micro ATX box though, can you say "toaster" ?
  4. 850 watts is enough for two GTX 480's in SLI:
  5. Thanks for all the help. It's actually either an 875 or 900 watt but I contacted Alienware and try say it's fine but I wanted extra confirmation And the temps arent a huge problem, it has been running pretty quietly. I did get the second card on sale so I'll see and if it doesn't work I'll try to return it. But idk. Thank you very much
Graphics Cards Gtx Power Alienware Graphics
