Are all of these parts compatible for my new build??? INTEL!
Hey everyone!
Thanks for taking the time to look at my thread :D I was just wondering if all of these parts that I'm about to list are compatible with one another, considering I don't know much about Sandy Bridge specs. I would just like to know if all these parts will work together, or if I need a different bridge type, or if I need to get a different CPU or Mobo so everything matches up! I think this should all work together without any issues, but it's always better to be safe then sorry!!!
Here's the list:
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=i7_2600k-_-19-115-070-_-Product
Power Supply - http://www.newegg.com/Product/Product.aspx?Item=17-182-239&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29#scrollFullInfo
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Graphics Card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130587&cm_re=nvidia_580-_-14-130-587-_-Product
CD/DVD Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100&Tpk=antec%201200%20case
Heatsink - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055&cm_re=V8-_-35-103-055-_-Product
Hard Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
That's all! Am I missing any parts? ^_- I don't think I am, but it's always nice to double check. I would love to have a few opinions on if this is compatible, so please message me A.S.A.P!!! Thank you!!! :D
`Ryan Callahan
2 answers Last reply
More about parts compatible build intel
  1. Looks good.
    The stock cooler for 2600K is pretty sweet, maybe try that for a while, not sure what kind of overclock your looking for.
  2. Not bad but:
    - If it's for gaming the cheaper 2500K is just as fast.
    - If you're spending $190 for a PSU make sure it says Seasonic, Corsair, Antec, Silverstone, XFX on it.
    - The 580 is too expensive for what you get, better get a HD 6970, the MSI Lightning or the Powercolor PCS+ are much cheaper and only slightly slower.
Homebuilt Compatibility New Build Systems Product
