Will this memory work on this motherboard
3 answers Last reply
More about will memory work motherboard
  1. That memory is a triple channel kit. It should work on that motherboard, but even if it does, it will run in either single channel, or with two sticks in dual channel and one stick in single channel. That motherboard can't run RAM in triple channel.
    Also, that memory will not be running at it's rated speed because the motherboard does not support it. If the RAM works, then it will be underclocked to 1066MHz, at best.
    Ok, thanks, thats all I needed to know.
  3. You're welcome.
Motherboards Memory Product
