jasonw223 :
I would say it's your memory. Might be a bad stick, or maybe incorrect timings or speed or something. Try running memtest,
Might be something else, and I can give you more tips later, but try that first.
Just doing a little digging around I thought to check "dxdiag". After looking at dxdiag I found out that have three different sound tabs. I do NOT have a dedicated sound card. I use the onboad realtek HD audio.
The three audio devices listed by dxdiag are as follows:
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1043841B&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6196 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 9/7/2010 19:27:34, 2484072 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
No problems detected on any of them.
I will run memtest today or tomorrow.
