Solved
$1600 system, ready to pull the trigger, please review
Approximate Purchase Date: This week
Budget Range: 1500-2000
System Usage from Most to Least Important: 95% games, 5% ms office/internet
Parts Not Required: monitor, keyboard, mouse,
Preferred Website(s) for Parts: newegg, amazon
Country of Origin: USA
Parts Preferences: no preference
Overclocking:Maybe
SLI or Crossfire: No
Monitor Resolution: 1920x1200
Additional Comments: none
Parts I have chosen so far:
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Scythe SCMG-2100 Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185142
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
EVGA SuperClocked 015-P3-1582-AR GeForce GTX 580 (Fermi)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.641809
CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER
Microsoft Windows 7 Home Premium SP1 64-bit English 1-Pack - OEM
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Total: $1484.39 + Tax + shipping = $1627.96
2 Questions:
I was thinking about getting SSD disk for windows 7 boot up but then I read about how they break and stuff. Are they that unreliable? And is the boot-up time that much faster.
How good is the sound on the motherboard, do I need to buy a SB card if I want good quality sound. (I also use USB G35 surround sound headphones)
Thanks guys
9 answers Last reply Best Answer
More about 1600 system ready pull trigger review
  1. Best answer
    PSU is a little overkill..a good 650-700(maybe 700) should be better! SSDs are reliable and can last thanks to Trim..be sure to take an Intel 320 Series which have 5 year warranty
  2. i'm going to place in an SSD tomorrow in my PC , will let you know if boot start-up speed is considerably faster
    Thanks!, let me know how it went and GOOD LUCK!
    No an 850w psu is not over kill for dual 580's. In fact a 900+w is what's usually recommended on here for dual 580's and room left. Try google next time.
    @ the OP. Look at dual 560's off the get go, get that case off of amazon and save yourself shipping cost. Also look at some combo's like the cpu + RAM, and look at the gigabyte UD3 P67X to save a few dollars + free shipping (newegg).
    That Samsung h/d can be had from amazon for cheaper also.
  5. amazon has no taxes so you might want to look to get your parts there they have the-
    i5 2500k same price
    asrock p67 extreme4 cheaper no shipping
    corsair vengeance 8gb 1600mhz (the blue one)
    i dont like the haf series they suck in way to much dust and their paint chips off over time. look into the nzxt
    phantom/corsair 600t
    spinpoint f3 1tb for 60$
    hx 850 cheaper by like a 1$ because no shipping costs
    the boot up time is a lot faster for ssd's and are reliable
    the onboard sound is pretty good you dont need an extra card
    get 2 560 ti's 40% better performance than a single 580 for less. the motherboard comes with an sli bridge and you can downgrade to a hx 750 at amazon. get this gtx 560 ti- http://www.amazon.com/gp/offer-listing/B004XUCCRM/ref=sr_1_5_olp?ie=UTF8&s=electronics&qid=1306856015&sr=1-5&condition=new get the same gpu at tiger direct because it is only 1 rebate per customer per household
    buy the dvd burner this one- http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216 , windows 7, the cooler & i think you need thermal paste with it- http://www.amazon.com/Mad-Dog-Arctic-Silver-Polysynthetic/dp/B0002VFXFE/ref=sr_1_1?ie=UTF8&qid=1306855901&sr=8-1 at newegg
    now no taxes just shipping cost from 1 gpu from tiger direct
    Really...he said he don't want to SLI, so 700W are enough for 1 580 and o/c cpu...read better next time...
    i5 2500k same price
    The corsair 600t case is really nice! I'm gonna order it instead of cool master.
    Thanks for letting me know:D
    I am gonna stick with 580 gtx though, i had sli setup when they first came out with the technology couple of years ago and I had a lot of problems with it. Basically i didn't see much improvement with 2 cards vs 1 even though I use 27.5" monitor.
    BTW gonna check out amazon for the prices, thanks for the heads up
  8. a couple years ago is a long time ago for technology sli/cf has gotten a ton better 2 560 ti's give you 40% better performance for less heres a review: http://www.hardocp.com/article/2011/02/21/msi_n560gtx_ti_twin_frozr_ii_oc_sli_review/8
  9. Best answer selected by Kleksgod.
New Build Systems Product
