Solved
Old CPU need new thermal compound help
Hi there!!
Im going to reuse my old AMD Athlon II X4 635 cpu on my new ASRock 970 EXTREME4 AM3+ motherboard (never done this b4...but going to try) and i have some questions i'll like to ask.
1.) Is Arctic Silver 5 Thermal Compound - OEM best to use?
2.) What more do i need besides the Thermal Compound and Heatsink/Fan that im also going to reuse or should i buy a new one?
3 answers Last reply Best Answer
More about thermal compound help
  1. Best answer
    Arctic Silver 5 3.5g Thermal Paste! if you are going to use a cpu or cooler with paste on it will will need to use Arctic Silver ArctiClean 30ml Thermal material remover and thermal surface purifier
  2. - most people said like that , it's the best
    - and if you had it follow this guide to applied
    www.hardwaresecrets.com/article/274/3
  3. Best answer selected by sunnyy.
CPUs Thermal Compound
