I am in the process of pricing out a full system around 2k$.
If you have any advice for me as far as the system goes then keep reading and thank you for the help.
It will be used for audio applications. This means it's priorities are:
1. Processing Power
2. Read/Write Speed for loading data/samples quickly (RAM and HDD's) with a minimum of 12GB ram and 120gb boot drive and 2TB slave.
3. Not being obnoxiously loud.
I need the minimum in graphics. I don't play games, and I need to be able to run 3 monitors for applications at 1080p relatively smoothly.
I have narrowed some things down but: I am trying to get the best parts in each category so if you know anything about which components to choose - then thanks for the help in advance.
________________________________________________________________
[CPU]
i7 2600k or i7 970 6 core?
[Motherboard]
Z68 Chipset?
3x PCI Slots
USB 3.0
2x gBit LAN (or) 4x PCI Slots for extra card
2xSLI
SATA 3 6.0gbps
[HDD's]
Boot drive - For the OS only
1 x SSD or 2 x SSD in RAID0 or 1 x PCI SSD
Slave Drive - For loading virtual samples. Basically 10-1000 MB libraries/samples that need to be loaded into the RAM randomly - a lot of the time as I work.
2 x 1tb Sata 3 RAID0
What raid controllers?
[Power Supply]
What do I need? 1000w?
[GPU's]
What to snatch?
[RAM]
What clock speed? 1333? 1600? 1800?
[Case]
I was thinking NZXT Phantom?
http://store.nzxt.com/product_p/cr-phantom.htm
[Fans, cooling, Controllers]
Liquid cooling?
Silent fans?
Special heat sinks?
Fan Controller?
[CD Drive]
1 x CDRW + DVDR thats really all. Just something cheap that can read standard disks and DVD's. Blu-ray is not a must.
[Sound]
None.
[Cabling/things I need to put it all together]
1. Processing Power
[CPU]
[Motherboard]
Z68 Chipset?
3x PCI Slots
USB 3.0
2xSLI
SATA 3 6.0gbps
[HDD's]
[Power Supply]
[GPU's]
What to snatch?
[RAM]
[Case]
Liquid cooling?
Silent fans?
Special heat sinks?
Fan Controller?
[CD Drive]
[Sound]
None.
