Counter Strike 1.6 FPS problem .. URGENT
hello guys ,
i need you urgent help because my Tournament is going to start from day after tomorrow of counter strike 1.6 online.
i have 2GB DDR2 RAM, Intel duo core, Nvidia 8600GT. Now the problem is that when i play cs 1.6 i am getting 60 fps i don't know why.
but i was use to get full 100 fps. this problem has started 2-3 days back.
So as obvious i cant play tournament with this FPS ...
please help me guys as fast as possible
i have done all setting in Nvidia Control pannel.
fps_max 101
fps_moden 101
developer 1.
{sorry for bad english }
Hope you all will help. :bounce: :pt1cable: :D
8 answers Last reply
More about counter strike problem urgent
  1. Check the game options and Nvidia Control Panel to see if VSync is enabled. If it is, disable it.
  2. +1 to VSync
  3. I don't think CS 1.6 has the V-sync enable option. I always get 101 fps whenever I play that game (which isn't often seeing as it's over 10 years old lol)
  4. The Nvidia Control Panel has an option to override VSync settings, and it looks like it has been enabled somehow. You should try to disable VSync.
    Your other option is, since CS is an OpenGL game, you may also be able to enable Triple Buffering with VSync enabled to increase FPS above the 60 hz refresh rate.
  5. ^ Which raises the point, that there most likely is no point in going above 60FPS. I suppose OP might be on a CRT which it could help with... a little... but if it's an LCD it probably won't change anything.
    Also, I'm always a little surprised people still play a game like this competitively. This one and Starcraft come to mind as really old, out dated games, that are still popular.
  6. The 60fps vs 120fps is a long long discussion full of flaming, he said she said, and some times, though rarely, facts. Maybe not in this thread :)
    hershgupta, have you tried looking for the VSync option? Also, have you updated your video card drivers?
  7. Counterstrike 1.6 Tournament??
    Wow that does sound urgent.
    Well, maybe Starcraft is outdated, but CS 1.6 has everything CS:Source has except for pretty graphics.
Nvidia FPS Graphics
