Recent build
HAF-922
Asus P6TD-Deluxe 1366
I7-950 /Corsair H50 cooler
EVGA GTX465-1/275.33
Corsair TX750W
Corsair XMS3 4GBx3 memory
BD burner
multiple USB devices
Win7-64
Temps:
CPU average-43c
GPU average-45c
MB- average-45c
I dont believe I have a power issue but not for sure, all drivers are up to date except latest video 280.26, read there may be heat issues, I will wait a bit on that.
After a bit video will freeze sometimes recover and sometimes not-reboot only option at this point. IE8 seems to be the worst at causing the trouble but not exclusive. I can reboot and the trouble seems to continue, however I recently discovered that if I shutdown and remove power to p/s leave off for a bit the next logon runs excellent for a while.
I believe I have a H/W issue but am puzzled. I have tested with MB out of case as well,same same. I am thinking video card first then possible MB. Seems if I open additional programs after being up a while this causes the video driver to stop then recover, possibly the video mem? I have swapped the system mem around and tested as well, NTF
Update: for sure does better after powerdown for a bit
Any known way of testing the video card, I may stick a cheap PCIe 2 in and see what happens.
I greatly appreciate any thoughts and comments,
Pat
HAF-922
Corsair TX750W
BD burner
Win7-64
Temps:
CPU average-43c
GPU average-45c
MB- average-45c
Pat
