Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > My First Home-Build-Really Need Help!
Forum Systems : New Build My First Home-Build-Really Need Help!
Hey guys,
So I am COMPLETELY new to building PCs but I said I'd give it a go as I've heard it would be cheaper than buying a pre-made and I'm also incredibly curious as to how all the different part of a computer go together so I was hoping it would be a success.
I have been asking various people online for their help for the last week but a lot of the people I have asked have been like "GET THIS..AND THIS...AND THIS" with no regard for my budget so I was hoping I could post here and get some really good constructive feedback.
I'll post the thread in the format that was listed in the stickies:
_______________________
Approximate Purchase Date: This week.
Budget Range: £~700 (800 euro ish)
System Usage from Most to Least Important: World of Warcraft, Starcraft II, Photoshop, Other Games (I don't play too many other games - I will be playing Diablo 3 when that comes out)
Parts Not Required: Speakers, Mouse and Keyboard are not needed.
Preferred Website(s) for Parts: Scan.co.uk ( I am Irish and these seem to be one of the few companies who deliver here so I reckon I'm stuck with them!)
Country of Origin: Ireland
Parts Preferences: Absolutely no preference.
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1920x1080 ideally.
___________________
I have constructed two builds on scan.co.uk that are the creation of this weeks research. One group of people believe that I should get an Intel i5 2500k and overclock it and make a sacrifice on the GPU. The others believe saving money on the CPU/Mobo by buying AMD will allow me to get a better GPU and will over all be a better system for what I need (that being said I have heard that WoW and SC2 are mainly CPU dependent, not GPU. I don't know if this is true or false). The only problem is, the Intel build is coming in at £50 more than the AMD one, so the AMD one is currently tempting me a lot as the lower the price the better!
Here are the two builds:
Intel:
http://www.scan.co.uk/savedbasket/ [...] 08e545a899
AMD:
http://www.scan.co.uk/savedbasket/ [...] 0198bc2c3f
Please keep in mind that a monitor is included in each build.
___________________
Can anyone here PLEASE help me out and help me create a build that will be good enough for my needs. I am not sure the parts I have chosen are the best quality/price on scan.co.uk , I have currently only really chosen what I have read about/been referred to so ALL the parts are completely subject to change. If anyone would be kind enough to perhaps link a build on scan.co.uk that would be above and beyond what I expect.
I would just like to thank anyone who made it to the end of this post, I realise it's very long and probably very boring for most of the experienced builders here but its a pretty big investment for myself (just out of college and sitting on pretty big loans but my 6 year old laptop is on its last legs so this is a priority) so I really want to get it right.
Thanks once again,
Kind Regards,
Tsukimi
Reply to Tsukimi
Build the intel , but drop the cpu to a 2400 , and spend the money you save on the better graphics card
Reply to Outlander_04
- 0 +
Is the 2400 still better than that AMD as well?
Reply to Tsukimi
- 0 +
Is the 2400 still better than the AMD one?
Reply to Tsukimi
but then he would not be able to overclock in the future.
and to OP i would highly reccommend buying from ebuyer, with free PandP for orders over £50 and very competitive prices. and the 2400 is still better than the AMD.
Message edited by ps3hacker12 on 06-04-2011 at 12:09:34 AM
------------------------------ HIGHEST OVERCLOCK RECORDED (9GHZ):
http://bit.ly/SvyUi
"Well, there may be a reason why they call them 'Mac' trucks! Windows machines will not be trucks."-MS CEO S. Ballmer
My Rig
Reply to ps3hacker12
Go 2400k and get a 6870 AMD card and 4 gigs of ram. I had that but with an AMD Athlon and it ran great the I5 would only make it better. You would be able to run any game you want at very close to max settings and in the future you could just drop a second card in instead of getting a new system. That would last you a long time (in computer years lol) I think In US dollars you could mayby go with a 6950 AMD card that would be even better. Dont over spend on ram you will see better results getting a better CPU/GPU. WoW And starcraft do seem to be very CPU dependant but with WoW you will only see changes from 75-100+ FPS any decent cpu/gpu combo will run that game at max setting over 60 FPS and at 60 FPS the game is very smooth.
------------------------------ Bisostar TA890FXE, Phenom II X4 965 OC 4.1ghz, MSI Twin Frozer 6950 OC to 940 core 1450 mem, 6GB 1333 DDR3 RAM, CM HAF 922 case, TR2 750w PSU
Reply to cburke82
- 0 +
Thanks a lot cburke I'll try and make a build similar to that so; can you recommend a decent motherboard that isn't too expensive that would be compatible with those components?
Reply to Tsukimi
For quality anything from asus or msi I have had great luck with this biostar. I would not want to reccomend a specific mobo as I have no experiance with the sandy bridge chips. But Biostar seems to give you alot for the money.
Reply to cburke82
lol the 2400K doesnt exist, the only i5 that has an unlock multiplier is the 2500K.
http://bit.ly/SvyUi
My Rig
Good job you passed my test... yeah thats my story and Im sticking to it lol
Reply to cburke82
- 0 +
Okay so I found that the German site was actually going to come in way cheaper so I'm ordering off that + Amazon and Komplett now. Below is the updated build, as always please suggest things that could be improved;
UPDATED BUILD:
NZXT Classic Series GAMMA - Mid tower - ATX - no
(http://komplett.ie/Komplett/site/Catalog/ItemDetail.aspx?ItemNo=15572609)
Intel Core i5-2500K Box, LGA1155
(http://www4.hardwareversand.de/articledetail.jsp?aid=41224&agid=1617)
MSI P67A-G45 (B3), Intel P67, ATX, DDR3
(http://www4.hardwareversand.de/articledetail.jsp?aid=46898&agid=1601)
4GB-Kit G-Skill Ripjaws PC3-10667U CL9
(http://www4.hardwareversand.de/articledetail.jsp?aid=29670&agid=1192)
Super-Flower Amazon 80Plus 550W
(http://www4.hardwareversand.de/articledetail.jsp?aid=30069&agid=1628)
EVGA GeForce GTX 460 - 1GB, PCI-Express
(http://www4.hardwareversand.de/articledetail.jsp?aid=38244&agid=707)
Samsung SpinPoint F3 1000GB, SATA II (HD103SJ)
(http://www4.hardwareversand.de/articledetail.jsp?aid=28152&agid=689)
LG DH18NS schwarz bare SATA II
(http://www4.hardwareversand.de/articledetail.jsp?aid=39120&agid=834)
Arctic Cooling Freezer 7 - Pro PWM Rev.2
(http://www4.hardwareversand.de/articledetail.jsp?aid=28345&agid=669)
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor
(http://www.amazon.co.uk/gp/product/B002UJ31A0/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=04QKDHY24FCZX15EX8KB&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294)
I'm also going to buy a case fan or 2 (120mm) but I'm not sure which ones so suggestions would be great.
I also need to get a new keyboard, but I just want something standard like the Microsoft Digital Media Keyboard 3000 ( http://www.amazon.co.uk/Microsoft- [...] 29&sr=8-4) but I can't find anywhere that stocks it for less than €30 which is too expensive for it imo.
Thanks a million guys
Reply to Tsukimi
first i would replace that board with this one:
http://www1.hardwareversand.de/art [...] &agid=1601
will save you some cash (yes i speak german :) ) and will allow for SLI/Crossfire in the future.
i would replace that GPU with this:
http://www1.hardwareversand.de/art [...] &agid=1004
comparison of your evga 460 vs the 6870:
http://www.hardwarecanucks.com/for [...] udy-6.html
everything else is good, the reviews for that PSU seem good too:
(similar super flower): http://www.anandtech.com/show/2643
http://bit.ly/SvyUi
My Rig
- 0 +
Just a quick update before I order, hopefully some people can give me some more feedback as I hope to order tonight! Thanks for all the help prior to this post:
http://komplett.ie/Komplett/site/Cat...temNo=15572609
MSI P67A-C43 (B3), Intel P67, ATX, DDR3
http://www1.hardwareversand.de/art [...] 601&apop=3
http://www4.hardwareversand.de/art [...] &agid=1617
http://www4.hardwareversand.de/art [...] &agid=1192
Gigabyte GeForce GTX 460 OC, 1024MB GDDR5, PCI-Express
http://www1.hardwareversand.de/art [...] 7&agid=707
http://www4.hardwareversand.de/art [...] &agid=1628
http://www4.hardwareversand.de/art [...] 2&agid=689
http://www4.hardwareversand.de/art [...] 5&agid=669
LiteOn iHAS124-19 schwarz SATA
http://www4.hardwareversand.de/art [...] 4&agid=699
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor http://www.amazon.co.uk/gp/product/B...pf_rd_i=468294
It will be mainly used for World of Warcraft, Starcraft 2 and Diablo 3, with alot of Photoshop for college etc thrown in!
I'd love if someone could also recommend a decent budget keyboard that's quiet :P I HATE loud keyboards!
Let me know what you think!
Reply to Tsukimi
- 0 +
Bump...anyone?:P
Reply to Tsukimi
if you are planning to overclock in the future i would replace that ram with this:
http://www4.hardwareversand.de/art [...] &agid=1193
http://bit.ly/SvyUi
My Rig
There are 2092 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 1 hour ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
