Closed
Will this ram work with my motherboard?
Last response: in Memory
May 18, 2012 6:21:12 AM
Hi.
LINK TO RAM::
http://www.newegg.com/Product/Product.aspx?Item=20-231-...
LINK TO MOBO/SPECS:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01...
I was stupid and ordered it without confirming. But then I saw something in 1 egg comments that said something about timings and power ratings. I'm rather new to all the technical terms (never replaced any computer parts before or done much of anything inside a tower) so please give me as much of an explanation as possible. Thanks.
More about : ram work motherboard
Best solution
a b } Memory
a b V Motherboard
May 18, 2012 6:37:11 AM
yes, this will work fine.
May 18, 2012 6:39:41 AM
k thank you.
anything I should know about installing this ram in specific? with all the talk of timing and voltage?
Score
a b } Memory
a b V Motherboard
May 18, 2012 6:42:10 AM
afewquestions said:
k thank you.
install the ram, start your pc, it will be randomly accessed.
Score
May 18, 2012 7:03:33 AM
Okay.
The only reason I ask is because it seemed quiter a few people had a problem with it, because they needed to change BIOS settings. Like this excerpt from the G.Skill Support.
"The timings are not standard for this memory kit, so you will need to manually input them in BIOS. The memory will boot with default settings, then you need to configure DRAM frequency, timings, and voltage. With the proper settings, you should have no issues. For any further questions or issues, please feel free to contact us directly."
Score
May 18, 2012 8:24:22 AM
Best answer selected by afewquestions.
Score
a b } Memory
a b V Motherboard
May 18, 2012 8:54:28 AM
ok, if you're facing any issue then contact..
Score
a c 146 } Memory
a c 328 V Motherboard
May 18, 2012 10:36:21 AM
This topic has been closed by Nikorr
Score
