Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > HELP! Peculiar overclocking, bsod crisis
Forum CPU & Components : CPUs HELP! Peculiar overclocking, bsod crisis
Hello,
My build:
AMD PHENOM II X6 1055T @ 3.5
CORSAIR XMS3 4GB KIT
SEASONIC M211 620W
Not long ago i've been having really bad bsod related to memory problems. this happened even though i installed a clean OS.
I tried troubleshooting the memory and apparently it has no issue, the hard disk also wasn't at fault ( i completely reformatted it and even used the tool provided by seagate )
But now the thing is that i realized that each time i power up the PC, ( my settings are OC'ed ).
I just need to enter the BIOS, reset my clock settings to 200 which is the stock setting ( 2.8 ) save and exit.
This causes the PC to shutdown momentarily ( the fans, led's hard disk etc turn off ) and back on again. After which i am able to enter the bios and key in 250 which will give me 3.5ghz.
Now i know that people can hit up to 3.9 stable and my voltage is only at 1.38. I have been doing this reset thing for months and i hadn't had one BSOD.
I really have no idea whether is it the power supply or motherboard issue?
A little help from anyone?!
Thanks alot guys!!!
didles
Reply to didles
I'll assume that you mobo is Gigabyte, am I right?
------------------------------ Installing the CM Hyper 212+
AMD Overclocking Club
Member Rankings: Points, status and badges
Doesn't work? Send me a PM.
Reply to saint19
do you have your ram in the outter 2 slots?
Have you stepped down your hypertransport and memory clock mulitpliers by 1?
Reply to popatim
hello,
Sorry for the late reply!! Im currently serving National Service thus don't have the time to come online!
First i wanna say thanks for the reply!
No i'm actually using Asus m4a89gtd Pro
I flashed it to the latest bios.
I only have rams installed in my 2 inner slots ( nearer to the cpu )
im running HT at 2000, memory is at 1333!
I suppose these are very stable speeds?.
I suspect it has something to do with the motherboard vrm or phase regulators ( something to do with power? ) because of the reset symptom i have...
Any insights?
Thanks!!!
Reply to didles
hello,
Any insights?
Thanks!!!
Reply to didles
when you go back in and key in 250 thats changing the Front Side Bus. (FSB) and when you change that you also change the speed of the PCI, PCIe, HT, and memory busses.
HT speed is 10x fsb so 250 would be pushing it at 2500. You need to change this multiplier to 8 unless your motherboard does it automatically.
Repeat for the other affecteds busses... esp memory since that is where you are having issues
Really you should consult an overclocking guide for your chipset or motherboard. You should have been aware of these thing before you began overclocking.
Reply to popatim
There are 2105 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 6 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
