700 € Limit game system (help me) advice
I want
4 year limit game system
700€ = 1.615 TL turkish
1022$ 1,615 TL turkish
1.615 TL Limit
Can't run cod: black ops
can't install
old processor
my problem graphic card
Okay processor
Intel i5 2500 (lga 1155 socket:)
graphic card problem
4 year limit one graphic card
how many years limit ati hd 5750??
3 answers Last reply
More about limit game system help advice
  1. OK. it is hard to help you because you don't provide the outlets where you can buy your parts from.
    Any rig you build will last 4 years, but it will be technologically outmoded in 4 years.
    For a system that can run any current game (although maybe not at highest settings) and would be within your budget of $1022 if bought at Newegg US.
    i5 2500K $225
    Mobo ASRock Pro3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157249 $110
    PSU Corsair 600W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028 $60
    RAM GSkill 4 GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277 $50
    Graphics Card GTX 560 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446 $200
    HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
    $65
    Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129096
    $80
    DVD Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
    $21
    Now this comes to $811, leaving you room for a Monitor, keyboard, mouse & other peripherals, and an OS.
    If there are things that you don't need you can upgrade the GPU (to a GTX 560 ti or AMD 6950 for about $250) more RAM and other improvements as you see fit.
  2. Asrock bad brand
    best brand msi
    Asus bad
    best geforce
  3. No, ASRock is one of the best rated brands currently. Geforce is not a brand, it is Nvidia's trademark. There are several OEMs selling Nvidia GPUs.
    Good luck and buy what you see to be the best.
New Build Graphics Cards Games Systems Product
