Solved
[HELP] Working on a new system
Ok I need a few questions answered because I've had this old rig for quite some time now.
My system as of NOW (No Changes):
BASICS
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601)
BIOS: Phoenix - AwardBIOS v6.00PG
Proccessor: AMD Athlon(tm) 64 Processor 3800+, ~2.4GHz (1 Core)
Memory: 4096MB RAM
DirectX Version: DirectX 11
DISPLAY - Have a 21.5" Acer Monitor (From a 16" CRT Monitor)
Video Card: NVIDIA GeForce 9400 GT
DAC Type: Intergrated RAMDAC
Approx. Total Memory: 2032 MB
Current Display Mode: 1920 x 1080 (32bit) (60Hz)
QUESTIONS:
1. What should I change first (What is the most important to change?):
2. What is the worst thing about my system as of right now (Even if all of it is bad what should I change first and why?):
Extra INFO:
- Gaming is what I tend to do, especially Diablo III.
- Price isn't necessary right now but I'm looking for mid-range. (discounts are important)
Thanks!
19 answers Last reply Best Answer
More about help working system
  1. Does it do what you like it to?
    If no what tasks do you need more performance in than its giving you?
  2. Questions: What do you do with your computer? How much are you looking/willing to spend?
    Suggestions: I would say the worst is a tie between your graphics card and your cpu. Upgrading either would result in increased performance, as to which one first I would say graphics card. Where are you located? What stores can you buy from?
  3. Gaming is what I tend to do, especially Diablo III.
    EDIT:
    And why my gfx card over my processor? It's a single core with 2.4GHz.
  4. Graphics card is more transferable to a future new system. Didn't read that it was a single core, then I would definatly upgrade that. Heard of geeks.com? Check there for an am2 or am2+ cpu unless your cpu can get new bios to be compatible with AM3 processors in that case I would recommend a Athlon II x3 as a good choice to upgrade too.
    What about this CPU?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
    It has 6MB L3 Cache instead of L2 Cache: 3 x 512KB - Is there any significance? And its a quad core over triple core.
  6. The question still is what motherboard do you have? If the bios can be updated to support socket AM3 processors then yes I recommend the upgraded but have you considered this processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808 its $25 cheaper and in two minutes can be the same thing as the one you suggested. If you could provide your motherboard manufacture and model number we could solve these questions. Hope this helps.
    Motherboard Properties:
    Motherboard ID 06/30/2006-C51/MCP51-A8M2N-LA-00
    Motherboard Name Unknown
    If that helps at all...
    Found the motherboard: A8M2N-LA (Naos)
  8. Im getting a make/model of Asus A8M2N-LA and are for HP desktops. Is this the case? If so I suggest you look on HP's website for bios updates to your specific desktop model # and let us know if you find anything or if you post the model # (assuming you have an HP) we could try and be of help.
    Model #: SR2013WM
    But im honestly looking to get whole new hardware itself so a new motherboard with a CPU would be excellent if you could show me what's best for gaming in terms of mid-range & discounts are important.
  10. Checking the HP/Compaq website got me this http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3300335#N152 which is no help. I am going to assume that since the motherboard is oem to HP only (read that quick in the Asus support forums) they never released a bios update themselves that would support an AM3 processor. If that is the case (I could be wrong) then my only for sure answer would be to tell you that in order to support an AM3 socket cpu you would have to buy a new motherboard. As it looks from your system specs I would suggest a core system (CPU, MOBO, GPU) update salvaging as many parts from what you have now as possible.
    Thanks.
    What would you suggest for a new motherboard / CPU for a mid-range gaming computer and why did you choose those parts? (Diablo III and most of the new 2011 games coming out for PC)
  12. Well first thing would be your budget and if you plan to reuse things like you HDD, Ram?
    Around 800-1000$
    I'll be getting new Ram aswell and no new HDD for now.
  14. I would like to know what you use you computer for before I give hardware recomendations. Such as what programs you run, games you play, or other tasks?
    Diablo III will be a big one and I would like to play most if not all my games on the highest detail with little to no lag as possible.
    Starcraft II, QuakeLive, Hunted Demon Forge, Black Ops.
    Multitasking with google chrome (facebook, email, youtube and etc.)
    Photoshop & iTunes.
    1920 x 1080 resolution.
    PS: I'm a big detail freak and love when my games are played to there fullest.
  16. Best answer
    Based on the following three performance tests I will suggest some possible build ideas that would fall into your budget range. http://www.techspot.com/review/305-starcraft2-performance/page7.html, http://www.techspot.com/review/336-cod-black-ops-performance/page5.html, http://www.techspot.com/review/405-the-witcher-2-performance/page5.html
    CPU- Intel Core i5 2400 $190 or Intel Core i5 2500k $225
    GPU- Nvidia GTX 560Ti $240 or AMD Radeon HD 6950 1Gb $240 Or Higher if possible
    Motherboard- P67 ASRock Extreme 4 $160 Z68 Gigabyte UD3P $160 Depends on your connection needs, perfered brand (if any), and style choices
    PSU- Single card- Corsair CX600 V2 600w $70 or Silverstone Strider 600w $70
    Multicard- Antec Earthwatts 750 750w $90
    RAM- 4Gb GSkill Ripjaw X DDR3 1333mhz $47
    8Gb GSkill Sniper DDR3 1333mhz $80
    Case- Really subjective hear. A few personal picks
    CoolerMaster HAF 912 $60
    Zalman Z9 Plus $70
    CoolerMaster CM 690 II $80
    CoolerMaster Storm Scout $90
    NZXT Tempest Evo $110
    NZXT Phantom $140
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600094002%20600107147&IsNodeId=1&name=GeForce%20GTX%20560%20Ti%20%28Fermi%29
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600083901%20600095873&IsNodeId=1&name=Radeon%20HD%206950
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128493
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817256071
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231438
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119215
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146062
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
    Prices Lowest- $767 Highest- $922
    As you see I have covered the range of your budget, opting out of the cost of a new HDD and DVD drive as I feel you could reuse those. Newegg Links are in order of when the parts was first suggested. Hope this gives you some ideas.
  17. Best answer selected by Scottehs.
  18. Thanks man ill definitely check out those links.
    Appreciate the effort!
  19. No problem, I am glad to be of any help.
New Build Systems Product
