S stealer0517 Distinguished Jul 14, 2011 82 0 18,630 May 19, 2012 #1 I recently purchased the gigabyte 990fxa-ud3, and with the rear audio ports i get no sound out of my speakers. I downloaded the drivers from the dvd but nothing comes out of them. any tips?
Solution C C cmichael138 May 19, 2012 Here's the drivers from Realtek's site if you want to try them. Just select the driver for your current OS. Just click on the "I accept" and "Next" http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
C cmichael138 Distinguished Jan 27, 2008 1,430 0 19,460 May 19, 2012 #2 Which drivers did you install? Upvote 0 Downvote
S stealer0517 Distinguished Jul 14, 2011 82 0 18,630 May 19, 2012 #3 The latest from gigabyte Upvote 0 Downvote
C cmichael138 Distinguished Jan 27, 2008 1,430 0 19,460 May 19, 2012 Solution #4 Here's the drivers from Realtek's site if you want to try them. Just select the driver for your current OS. Just click on the "I accept" and "Next" http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false Upvote 0 Downvote Solution
S stealer0517 Distinguished Jul 14, 2011 82 0 18,630 May 20, 2012 #5 I fixed it when I pouted in my device to the audio out it said somthijg like "what do you want to set this device up as?" And I said somthing odd Upvote 0 Downvote
S stealer0517 Distinguished Jul 14, 2011 82 0 18,630 May 20, 2012 #6 Best answer selected by stealer0517. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 May 20, 2012 #7 This topic has been closed by Nikorr Upvote 0 Downvote
