$400 i3 2100 Build need help
Approximate Purchase Date: In the next couple of weeks
Budget Range: $400 or as close as possible if need be.
System Usage from Most to Least Important: Internet/Youtube, Casual Gaming (Sims 3 and flash games)
Parts Not Required: keyboard, mouse, speakers, Monitor
Preferred Website(s) for Parts: Newegg.com, Tigerdirect.com and Amazon.com
Country of Origin: USA
Parts Preferences: i3 2100, 2GB of RAM and Windows 7 Home Premium (64bit)
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1440x900
Additional Comments:
1. I won't be gaming a lot and even when I do the most intense it will get is Sims 3 but, I still want it to look good when I do.
2. Right now I'm using a 10+ year old computer and its starting to have trouble streaming Youtube and such.
3. I have some parts picked out but, I'm not sure on others.
CPU: Intel i3 2100 - $125
GPU: If Sims 3 is as intense as it gets, will the integrated graphics do?
PSU: Since I don't know about the GPU I'm unsure how big of a PSU I need
MOBO: Here's a few, let me know what you think;
ASUS P8H67-M LE (REV 3.0) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard - $105
GIGABYTE GA-H67M-D2-B3 LGA 1155 Intel H67 SATA 6Gb/s Micro ATX Intel Motherboard - $90
RAM: Will 2Gb be enough?
CORSAIR XMS3 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model TW3X2G1333C9A G - $30
Optical Drive: SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache EIDE / ATAPI 22X DVD±R DVD Burner - OEM - $21
Case: Unsure right now
Hard Drvie: What would you recommend? I'm okay with a 250gb tho, no higher than 500gb is needed (unless its the same price).
Operating System: Microsoft Windows 7 Home Premium SP1 64-bit English 1-Pack - OEM - $100
Help is needed :) Thanks in advance.
3 answers Last reply
More about 2100 build help
  1. Few suggestions: CPU- i3 2105 if its availible, why? The 2105 has Intel HD3000 graphics versus the 2100's Intel HD2000 graphics http://www.newegg.com/Product/Product.aspx?Item=N82E16819115090
    RAM- 4Gb kits can be had for $40 and would be a worthwhile upgrade http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
    Case- NZXT Gamma $35 http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
    or look for a case with at least two fans if you don't like this one
  2. I'd try hard to start with at least a 4 GB kit......
  3. Any other suggestions? Thanks for the replies.
New Build Systems Product
