Need some info on new build.
- New Build
Graphics Cards
- New Build
Systems
- Product
Last response: in Systems
Exarr
June 5, 2011 6:05:58 PM
Ok i need a little help, i am building a gaming rig and want to stay under $1000 i have some stuff listed below. Tell me what you guys think and i want to make sure everything is compatible and also need some help on picking some video cards.
CrossFireX: Yes
Case: Sunbeam - http://www.xoxide.com/sunbeam-transformer-case-black.ht...
Mobo: Asus - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU: AMD - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
PSU: Carsair 750W - http://www.newegg.com/Product/Product.aspx?Item=17-139-...
And thats all i have so far please let me know if you have any suggestions and i would like some help on the video cards and some other options as well (HDDs, Blue Ray drives ect.) and i want to try to keep it under $800 but can go $1000
CrossFireX: Yes
More about : info build
Hi Exarr, please fill out this form, it will allow us to help you more efficiently. http://www.tomshardware.com/forum/261222-31-build-advic...
m
l
Best solution
mgf derp
June 5, 2011 6:14:06 PM
Based on the following three performance tests I will suggest some possible build ideas that would fall into your budget range. http://www.techspot.com/review/305 [...] page7.html, http://www.techspot.com/review/336 [...] page5.html, http://www.techspot.com/review/405 [...] page5.html
CPU- Intel Core i5 2400 $190 or Intel Core i5 2500k $225
GPU- Nvidia GTX 560Ti $240 or AMD Radeon HD 6950 1Gb $240 Or Higher if possible
Motherboard- P67 ASRock Extreme 4 $160 Z68 Gigabyte UD3P $160 Depends on your connection needs, perfered brand (if any), and style choices
PSU- Single card- Corsair CX600 V2 600w $70 or Silverstone Strider 600w $70
Multicard- Antec Earthwatts 750 750w $90
RAM- 4Gb GSkill Ripjaw X DDR3 1333mhz $47
8Gb GSkill Sniper DDR3 1333mhz $80
Case- Really subjective hear. A few personal picks
CoolerMaster HAF 912 $60
Zalman Z9 Plus $70
CoolerMaster CM 690 II $80
CoolerMaster Storm Scout $90
NZXT Tempest Evo $110
NZXT Phantom $140
http://www.newegg.com/Product/Prod [...] 6819115074
http://www.newegg.com/Product/Prod [...] 6819115072
http://www.newegg.com/Product/Prod [...] 28Fermi%29
http://www.newegg.com/Product/Prod [...] 0HD%206950
http://www.newegg.com/Product/Prod [...] 6813157229
http://www.newegg.com/Product/Prod [...] 6813128493
http://www.newegg.com/Product/Prod [...] 6817139028
http://www.newegg.com/Product/Prod [...] 6817256071
http://www.newegg.com/Product/Prod [...] 6817371026
http://www.newegg.com/Product/Prod [...] 6820231438
http://www.newegg.com/Product/Prod [...] 6820231417
http://www.newegg.com/Product/Prod [...] 6811119233
http://www.newegg.com/Product/Prod [...] 6811235027
http://www.newegg.com/Product/Prod [...] 6811119215
http://www.newegg.com/Product/Prod [...] 6811119196
http://www.newegg.com/Product/Prod [...] 6811146062
http://www.newegg.com/Product/Prod [...] 6811146067
Prices Lowest- $767 Highest- $922
Add a HDD to this list and it would be my recommend build without any knowledge of what resolution you want to play at or what games you want to play. Cheack this thread http://www.tomshardware.com/forum/forum2.php?config=tom... for working links
Zalman Z9 Plus $70
NZXT Phantom $140
- New first time custom build about $1500(need info as soon as possible) - Forum
- New PC Build wont power up! Need help and info! - Forum
- New to pc building, need info in overclocking - Forum
- New build need info 700 to 1000 - Forum
- Need some info for my new build. Is I7 930 > any I5 or I3? - Forum
Exarr
June 5, 2011 6:16:48 PM
Exarr
June 5, 2011 6:17:59 PM
mgf derp
June 5, 2011 6:22:38 PM
http://www.newegg.com/Product/ProductList.aspx?Submit=E...
These should work, or use the linked thread I posted for working links if these don't work.
m
l
Exarr
June 5, 2011 6:27:47 PM
mgf derp
June 5, 2011 6:31:08 PM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... CPU
http://www.newegg.com/Product/ProductList.aspx?Submit=E... GTX 560Ti
http://www.newegg.com/Product/ProductList.aspx?Submit=E... HD 6950
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ASRock
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Gigabyte
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Corsair
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Silverstone
http://www.newegg.com/Product/Product.aspx?Item=N82E168... GSkill
http://www.newegg.com/Product/Product.aspx?Item=N82E168... CoolerMaster
Those should be all the links you want to look at for the lower build
m
l
Exarr
June 5, 2011 6:33:03 PM
Exarr
June 5, 2011 6:38:14 PM
mgf derp
June 5, 2011 6:52:56 PM
Striker could you provide a link for the Antec for $69 as it is $74 on Newegg (I might buy it myself for $69) the Earthwatts would be a good upgrade over the Corsair or Silverstone as it is 80+ Bronze rated for power efficiency. Although both the Silverstone and Corsair are 80+ so they are no slouches either.
m
l
Exarr
June 5, 2011 6:58:35 PM
Exarr
June 5, 2011 7:03:33 PM
m
l
Exarr
June 5, 2011 7:39:35 PM
mgf derp
June 6, 2011 2:54:30 AM
Both motherboards I recommended are capable of SLI and Crossfire. As to which one I would recommend the P67 based ASRock. And when your talking about 6pin that is the connection between the psu and graphics card. the 6950 and GTX560Ti require two 6pin connectors a piece so if you wanted to do SLi/Crossfire(CFX) you would need a 750w power supply with at least 4 6pin connectors.
m
l
Exarr
June 7, 2011 3:00:47 AM
mgf derp
June 7, 2011 3:05:24 AM
two gtx 460's will still require 4 6pin connectors. You will not need a 750w for 560Ti Sli 600w will do the trick and 600w will be able to handle gtx 460 SLi. A 600w psu with 4 6pin connectors is the Silverstone Strider Essential 600w. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
Exarr
June 7, 2011 3:11:49 AM
Exarr
June 7, 2011 3:19:05 AM
Exarr
June 7, 2011 3:25:12 AM
Exarr
June 7, 2011 3:27:42 AM
m
l
Exarr
June 8, 2011 12:18:59 AM
A regular, cheapo $20 will get the job done. They are probably all made by liteon anyway. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
Exarr
June 18, 2011 1:20:17 AM
- New Intel build, need some info Forum
- Building new system need info Forum
- Needing info for new rig I want to build Forum
- Solved32bit or 64bit build. Need info Please Forum
- SolvedMonitor Help - New gaming monitor lost and need help. (Current Monitor/Video Card Info Included) Forum
- Solvednew rig need bf4 performence info Forum
- SolvedNeed info on what wattage to get for a new power supply Forum
- Need Info for new Setup :-) Forum
- SolvedNew Build Info Forum
- SolvedBuilding Video Editing Rig - Need info on the 3 Hard Drives line up Forum
- Solvedneed info on this build. Forum
- SolvedNeed recommendation on literature for building a P.C. Built two already (low end). Need info on WHY certain parts are needed Forum
- SolvedWill I need any type of liquid cooling system/fan etc.. for this current system I'm building? (system info provided) Forum
- SolvedDOS based business software with customer info that needs to be transferred to a new business software. Forum
- SolvedNeed info on building render farm into 1U & 2U chassis hopefully using gaming mobo's Forum
- More resources
