Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Inspiron 2650 doesn't work off the battery.
Forum Laptops & Notebooks : General Laptops & Notebooks - Inspiron 2650 doesn't work off the battery.
Archived from groups: comp.sys.laptops (More info?)
I have a DELL Inspiron 2650, model PP04L for some time now. At some
point PC stopped working on internal battery. I thought it's a
battery problem and have purchased the new one, with no luck. Even
though the battery Power meter in control panel shows 100% and
indicator on a battery itself turns green when button is pressed, as
soon as I disconnect the power plug, the laptop turns off. What should
I do? Thanks in advance.
Sponsored Links
When you find a solution , be sure and let me know. I have the same problem Tgoodwin@tgjazz.com
Reply to thomgood
There are 710 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
