How to save power/reduce heat with SLI setup???
Related ressources:
- ForumHow much of a power supply for a GTX 275 SLI / i7 setup ?
- ForumGetting lower FPS than i should with my 2 460 GTX SLI setup
- ForumGTX570 SLI Performance vs heat and spacing
- ForumI7 3770 Heat Tests in 85F Room Temps
- ForumThinking about building a SLI setup . Which mobo would you recommend?
- ForumRegarding a GTX 460 SLI setup and an AMD Quad
- ForumI7 K system, solid or should I save and upgrade more?
- ForumTri sli setup issues
- ForumBest PSU for my SLI 8800 GTX setup ?
- ForumZalman ZM-600-GT good enough for Sli setup ?
- ForumSli display configuration/ heat
- ForumMy gtx 285 tri sli setup ,any final suggestions before I buy it ?
- ForumIs this PSU ok for a gtx 285 tri sli setup ?
- ForumHow much watt's do I need for this setup ?
- ForumRandom Freezes and crashes, GTX 460 (fixed) heat problems now...
- ForumNo POST with new video card
- ForumHow Much Power?
- Forum[Solved] 6970 issue with GTA 4?
- ForumATI Radeon 6850 and 5770 Power supply requirement??
- ForumPSU needed for SLI gtx 570
- More resources
