Asus Xonar DX Sound card power Supply
  • Prebuilt
  • Power Supplies
  • Hewlett Packard
  • Sound Cards
  • Systems
Last response: in Systems
June 7, 2011 7:15:29 PM
My computer is Hp Pavillion Slimline 7610 Desktop,,Have fitted sound card and plugged power lead into back edge of card but cannot find plug/connector inside Pc to get power supply connected.. Can anyone help please..
More about : asus xonar sound card power supply
a b ) Power supply
June 7, 2011 8:04:32 PM
The Xonar DX sound card gets its power from the PCI slot it's plugged into. a separate power cable is not needed or required. The only connections on the card are the outputs for your amplifier, mic & line inputs and the digital S/PDIF.
OK...Just looked in the correct manual... The DX DOES require an additional power cable to work..My bad :pt1cable:
from the pictures it looks like either a standard power cable for a 3.5 " floppy drive, or Asus should have supplied an adapter that would take their power connector and matched it up with a standard molex plug from your PSU
m
l
October 7, 2012 10:15:09 PM
clarkjd, you are an idiot.Read the question properly and stop wasting our time.
m
l
