Front panel power problem
hi..im newbie here hoping that any one out there will help me with my problem in my desktop computer..
i have a GeForce6100PM-M2 motherboard..and the problem is my computer didn't turn on when i'm using the power switch in my PCcasing..this are the ff. method i'd try:
1. i Swap the Power Switch to the Reset Switch to try if it will turn on..NONE
2. i try to power my PSU using a paper clip,connecting the green and black wires..the PSU turns ON..so my PSU is not defective..
3.i try to tighten the connector of the power switch but nothing's happen..didn't turn's on
4.i clean the header of the front panel and connect again the power switch of the PCcasing..again..nothing's happen..
5.i try to jumper the power switch in the header,using a longnose pliers..it TURN'S ON..USING A PAIR OF PLIERS..i don't want to do that every time i open my PC..
please..help me..
please..help me..
More about : front panel power problem
Related ressources
- Problem with front panel power not powering up - Forum
- USB 3.0 front panel ports. One works, other gives power , no USB - Forum
- Power pled wires to front panel too short for new board - Forum
- Antec One front panel audio problem , no Jack Sensing - Forum
- Front Panel Connector Problem - Forum
sir ky_ecsusa..i think all the screws are in align with the standoffs..i just use 4 standoffs,in all the corners of the board..
sir scout_03..the ATX 24pins are OK..and the 4pins..
its hard for me to know what the problem is,.cause i think all of the components are OK..i check all the possible defective parts..but there OK..
please give me more ANSWER..i want to fix my computer..there are times that even i'm using a pair of longnose pliers to turn on the PC,the PC don't turn on..but after a while..after some tries to turn it on..it turn's on..i really don't know what the problem is..the problem is very rare for me..its the first time i encounter this problem..please help me..
thank you so much!!
thank you so much!!
you have to put all the stand off see 6 of them on the board page and they should be all aligned thoe board holes to put screw in then when you put back the connector check to place power switch + side to the same on the board see page 12 for the connector http://download.ecsusa.com/dlfileecs/manual/mb/eng/k8/G...
Try to remove all the wire between the case and the motherboard like USB front panel cable, audio front panel cable, LED light wire, etc. Then, only connect the power switch wire to the motherboard for testing. If it works, then one of the cables/wires will be the root cause for this issue.
In addition, you may try to test the motherboard without mounting inside the case.
If you have a debug card, you can try take out all the wires and remove all the hardware on the motherboard including CPU, memory, hard drive, etc. Just connect the Power switch wire from your case to motherboard. Trun on the system. If there is some numbers on the debug card, then the motherboard is OK. Mostly, the debug card will show either "FF" or "00". You may need to test all the hardware one by one. One of the hardware may cause this issue. If you don't see any number on the debug card, then it is possible that something wrong on the motherboard.
do you mean sir,a built-in led in the mobo?that turns on when the UPS or AVR are switch on?my mobo does not have that built-in led..
i've try this one just now..i disassemble all the parts and run the unit without the casing..i mean,i try to turn on my computer with the parts are in the outside of the casing..its the same..nothings happen..it turn's on..i use the pliers again and jumper it..it runs..but after i shutdown it..even i jumper it..it doesn't turn on anymore..
is it possible that my mobo is defective?
plug the system directly to the wall outlet do not use a ups,power should be on the psu also check if you did not move any of the jumper setting as mark page 9,also recheck all connector the 24 pins and the 4 pins +the cpu fan if they are all connected in and not loose.see page 12 and 13 try to find a momentary switch and connect the pin 6 and 6 then press that switch to see if system boot
You can contact ECS technical support for an additional help on this issue.
http://www.ecsusa.com/ECSWebSite/Support/Technical_Supp...
If you need more information, feel free to contact ECS Technical Support.
http://www.ecsusa.com/ECSWebSite/S [...] 50&LanID=9
Phone number: 510-226-7333 Option 6
9:00 a.m. - 6:00 p.m. Pacific Time
Monday - Friday
Monday - Friday
Related ressources:
- ForumASUS USB 3.0 Front Panel Box Problem
- ForumIs a front panel power switch required to test motherboard
- ForumFront Panel Question?
- ForumRosewill Thor V2 front panel USB kiss of death
- ForumFirst build - power on when plug in/ front panel advice
- Forum[ANTEC 200 ATX CASE] **DEAD** is it PSU or FRONT-PANEL CONNECTIONS?
- ForumPROBLEM SOLVED: how to connect front panel audio
- ForumASRock - Weird Problem front panel audio.
- ForumHDD use + front panel audio = static noise
- ForumFront Panel Audio Problems
- ForumTop/ Front Panel USB 3.0
- ForumHelp updating BIOS
- ForumDell Inspiron 530s Power On Issue
- ForumZotac Z68ITX-A-E Front Panel Audio problem linux
- More resources
Read discussions in other Motherboards categories
