Solved
Reinstall problem
  • Sound Cards
  • Sound Driver
  • Components
Last response: in Components
September 2, 2011 6:01:21 PM
hello everyone, anybody know how to reinstall my sound driver?
More about : reinstall problem
September 2, 2011 6:05:02 PM
Umm...you could use the cd that came with your motherboard or go to the manufacturers website....
m
l
September 2, 2011 6:21:28 PM
or at least tell us the make of your motherboard or pc or laptop--we cant read minds you know :D
m
l
Best solution
September 2, 2011 6:25:09 PM
Please click on this link: http://www.tomshardware.com/forum/292351-28-need-driver...
Or, alternatively:
I'm assuming you are not too familiar with your computer's hardware, but try this website: http://www.computerhope.com/issues/ch000503.htm
Follow it's instructions, it should tell you what you sound card you have. Using the name of that sound card, google that company's website and go to their support section to find their available drivers. Recall what type of card you have, and locate it accordingly on the manufacturer's site. Hope this helps.
September 3, 2011 3:01:05 AM
Best answer selected by ajme.
m
l
