Ok im having some issues I upgraded my computer from a crappy AND cpu and the fx-4100 cpu to a Asrock z77 extreme 4 and a i5 3570k cpu. I took out the old mobo and then installed the new one and cpu hooked it all up turned it on and then it goes to the windows screen saying it needs to repair i run that no good now I know I need to reinstall windows the problem in having is I cant figure out how to get it to run the CD I go into bios set it to boot from CD drive when I did it would turn on then shut off run from harddrive it will turn on for a few then shut off I'm stuck because I cant figure out what to do now and the user guide is not helping seeing its written as if you just built the computer not did a switch from AMD to intel. I was told this was supposed to be easy =/ not looking this way.
Computer when I bought it.http://www.newegg.com/Product/Product.aspx?Item=N82E16883229285
Specs now
i5 3570k
EVGA GTX 560 SC
corsair 650tx
rest is the same as before.
Specs now
i5 3570k
EVGA GTX 560 SC
corsair 650tx
